Removing Door Pins?
Removing Door Pins?
Do I need a special tool to remove the door pins and if so where can I get one?
1988 340 1.4 DL
Re: Removing Door Pins?
you wont need a special tool, only a punch or drift pin, you'll have to push from top to bottom
The top pins can be removed with a punch or old screwdriver, you need to lift off (carefully) the rain gutter strip top gain access. Once half way through use a new pin to finish and follow the old one out.
The bottom pins really need a door pin removal tool to remove upwards. I got one from ECP and it just about lasted for the 2 bottom pins. They are quite hard to get out.
Thanks, who are ECP and do they have a website? Also what size drift pin would I need? Surely someone on here must know!
Also this tool is advertised on ebay, I wonder if it will work on a Volvo 340?
1988 340 1.4 DL
looks pretty much like the one I got, didn't last very long. Those pins need serious removal power.
ECP - Eurocarparts, one from frost.co.uk might be better
http://www.frost.co.uk/item_Detail.asp? ... %20Remover
The bar or the pins? Pins are usually available separately as spares.Ride_on wrote:looks pretty much like the one I got, didn't last very long
Does anyone know what size punch I would need, 8mm possibly? It doesnt say in my Haynes manual.
1988 340 1.4 DL
You can just hit the edge of the pin, you don't need the full size, although with a crappy punch the corners will wear off.
I measured across the diameter of my replacement pins and they're 1/4". Im hoping Kevin Coopers will do a drift or punch thats the same size...
1988 340 1.4 DL
Hi Justin,
there are some posts with some good info on door pins on this site, check out these threads:
http://www.volvo300mania.com/forum-uk/v ... f=5&t=3615
http://www.volvo300mania.com/forum-uk/v ... f=5&t=8606
I just need to know what size punch I will need in millimetres?
1988 340 1.4 DL
Any punch bigger than a few mm will do. Whatever size you use you need a good hammer blow, that is the most important thing.
Has anyone actually used the hinge pin removal tool that (http://www.frost.co.uk) sell?
1988 340 1.4 DL
