Horn won't work - Desperate
kelvingenders
Post by kelvingenders » 21 Jan 2011 11:05 am
Could anyone show me a picture (preferably colored) of the connections going into the "black plastic that sits over steering column". This has two connectors. I really need to know, cause I'm finding that when I try to connect this up to wire i think could be correct....
a) the horns don't work
b) the wires get bloody hot
All of which tells me I'm not doing this correctly
This is for a 360 GLT B200EA model (MK3 ) Australian
Can anyone help with a picture?
Kelvin - Brisbane...The only man in Queensland to own a 360GLT :360: :360: :360:
Re: Horn won't work - Desperate
Post by Speedy88 » 21 Jan 2011 12:53 pm
Take your steering wheel and dash surround off until you see something like this:
See those 2 pins poking out just above the steering column? Stick a screw driver over those. Basically the horn push just completes the circuit for these. If that works then it's probably a contact problem between that and the horn ring or within the steering wheel itself.
Edit: Re-reading your post it appears you've already got to this stage :lol: Find the wires going into the back of these pins? I seem to remember one being purple but I'm not too sure...
kelvingenders
Post by kelvingenders » 21 Jan 2011 01:23 pm
Already got to this stage, I need to know which wires go the the wires attached to the black collar which sits on the steering column.
Thanks Kelvin
kelvingenders
Post by kelvingenders » 23 Jan 2011 01:46 am
Horn is now fixed..looked for more wires and trialled and errored - it now works
Kelvin-Brisbane
Post by Speedy88 » 23 Jan 2011 01:46 am
Winner :)
kelvingenders
Post by kelvingenders » 23 Jan 2011 02:35 am
looked at length of potential wires that could fit and Dual horn is rampant
pettaw
Post by pettaw » 23 Jan 2011 03:27 pm
just for reference, its normally a pink wire and a brown wire you need. Glad you fixed your problem Kelvin.
