rev limiter wiring on a 1.7 340
erixtar1992
Post by erixtar1992 » 01 Feb 2012 07:53 pm
hey guys, ive got a 1986 1.7 340 and i want to install my spark cut rev limiter,
the problem im having is that it has a wire which goes to the negative side of the coil. as i found out earlier the volvo has a different type.
so i need to know where to put the negative wire to on the 340's setup!
ive found this picture, but i dont know for sure. can anyone help?
cheers eric
Re: rev limiter wiring on a 1.7 340
Post by volvodspec » 02 Feb 2012 10:31 pm
it on non of the plugs, get a TX20 bit and unscrew the 2 torx bolts holding the coil, on the lower part of the 2 small clamps (the bit that doesn't move/hold the coil directly) you can quite easaly solder a wire onto; my rev limiter used both sides of the coil
as to wich is the negative, i thought it is the side near the A plug; but not 100% sure on that!!
erixtar1992
Post by erixtar1992 » 07 Feb 2012 06:07 pm
ah i see. ll try it. thankyou
erixtar1992
Post by erixtar1992 » 21 Feb 2012 04:56 pm
got it wired up in the end, negative was indeed the side nearest to plug a. there is a pin sticking out which i connected the limiter too. set it at about 4.5k at the mo
Post by Chris_C » 21 Feb 2012 07:02 pm
Thanks for updating, that's useful info
erixtar1992
Post by erixtar1992 » 21 Feb 2012 09:06 pm
Chris_C wrote:Thanks for updating, that's useful info
no probs. ill wack a picture up when i find one of the pin im taking about
