my warning light turns on and of while driving uphill with the throttle quite far in
and now it has started showing/blinking while driving normally on straights, starts when the revs get over 2000 rpm
anyone know what it could be?
i dont notice anything when the light shows, sometimes a little less power maybe, but that could be something in my head... paranoia may be getting me
It's the "surprise" light implemented by volvo in 1972. Basically if the Volvo doesn't expect something to happen, it will be surprised (such as when you start going fast) and let you know via the dash light. Hope that helps.
Chris_C wrote:Check your rear drums... the cylinders in there often start to leak
right one to be exact, found that out when trying to change the bearing
also took up smoking after trying to change the bearing, fucking thing wont move...
found that out to
and its only one brake circut in the rear, seems kinda weird to me, but it works
also, my car turns a bit to the right when braking, so gotto fix my brakes and calipers in the front to
