warning light
Posted: 31 Mar 2012 10:11 pm
by tim-andre
my warning light turns on and of while driving uphill with the throttle quite far in
and now it has started showing/blinking while driving normally on straights, starts when the revs get over 2000 rpm
anyone know what it could be?
i dont notice anything when the light shows, sometimes a little less power maybe, but that could be something in my head... paranoia may be getting me
Re: warning light
Posted: 01 Apr 2012 07:13 am
by trabitom99
Which warning light, not the brake fluid?
Re: warning light
Posted: 01 Apr 2012 12:24 pm
by volvosneverdie
((!)) is the brake fluid as Tom says. If its low, the light will flicker or come on under acceleration or uphill.
Re: warning light
Posted: 01 Apr 2012 12:43 pm
by Speedy88
It's the "surprise" light implemented by volvo in 1972. Basically if the Volvo doesn't expect something to happen, it will be surprised (such as when you start going fast) and let you know via the dash light. Hope that helps.
Re: warning light
Posted: 01 Apr 2012 03:29 pm
by tim-andre
volvosneverdie wrote:((!)) is the brake fluid as Tom says. If its low, the light will flicker or come on under acceleration or uphill.
its that sign.. good to know, then it must be leaking, started coming on more frequently lately...
Re: warning light
Posted: 01 Apr 2012 07:16 pm
Check your rear drums... the cylinders in there often start to leak
Re: warning light
Posted: 02 Apr 2012 09:55 pm
by tim-andre
Chris_C wrote:Check your rear drums... the cylinders in there often start to leak
right one to be exact, found that out when trying to change the bearing
also took up smoking after trying to change the bearing, fucking thing wont move...
Re: warning light
Posted: 07 Apr 2012 08:52 pm
by Nimminz
i remember thinking it was some sort of 'shift-light' as it only came on when accelerating hard. Turned out it were the rear cylinders.
Re: warning light
Posted: 09 Apr 2012 01:05 am
by tim-andre
found that out to
and its only one brake circut in the rear, seems kinda weird to me, but it works
also, my car turns a bit to the right when braking, so gotto fix my brakes and calipers in the front to
