headlight flash
oldscoolcart
headlight flash
Post by oldscoolcart » 10 Jan 2013 09:48 am
hi,
does a 340 have a headlight-flasher -to give a signal when going to overtake e.g.- or am i too simple to discover this?
i do only find the steering column stalk to switch between dipped and main beam and back.
anyone?
thank you.
Fuse
Re: headlight flash
Post by Fuse » 10 Jan 2013 02:29 pm
High beams shouldn't stay on when pulling the stalk if the head light switch is on the 0-position. If the switch is on the 2-position, then the high beams stay on when the stalk is pulled.
Headlights should be always on when ignition is on.
-Marko
Re: headlight flash
Post by Chris_C » 10 Jan 2013 03:35 pm
Fuse wrote:Headlights should be always on when ignition is on.
Not on UK spec cars chap, we didn't get DRLs
Fuse
Re: headlight flash
Post by Fuse » 10 Jan 2013 03:43 pm
Ok! Good to know. :-P
-Marko
