Rear door handle removal with picture
kelvingenders
Post by kelvingenders » 02 Apr 2013 08:26 am
Just trying to remove the rear door handle. I believe they are a little fiddly to get out . Can any one tell me what is the next part re the picture :360: sm2
Logan360
Re: Rear door handle removal with picture
Post by Logan360 » 02 Apr 2013 08:51 am
Hit it with a hammer! just kidding. had to pull one out for a guy a few months ago. undo that top screw and any others that look like they may be associated. that rusty one, don't bother. grab a flat head and bend the edges of that little square panel off the bars. Reach down the bars and you'll feel clips. These may come off with the handle out of the car I'm not sure. someone else may be able to help from here.
Own:
86 360GLT
97 S90
92 960S
92 960 Royal
91 960
96 Volvo 854R
Owned
E90 320 M-sport wagon
S60T -Mazda Familia
850lpt -AU Falcon
855 T5 -95, 97 960
940TIC -Mitsi GTO TT
16x 360 (1 GL, 2 GLS, 13 GLT)
Toyota corolla
R32 nissan skyline
Toyota corona
360vlov
Post by 360vlov » 06 Apr 2013 03:26 am
nah you can leave the rusty one. I found its better to take the 3 screws of the catch out on the side of the door to allow for movement(you'll know what i mean later when you lift the handle out. The screw behind the rusty one in yourpic should come out (it holds the handle in) and the handle should come loose. Its a bastard to get out and in, but you have to slide the handle away from the edge of the door as far as you can then tilt the handle upwards. Its a tight fit but the key is sliding it across as far as you can. Once the handle tilts up and out you'll notice a clip attached the the lever, simply push it out. Ddon't loose the liitle grommet thingy that keeps the clip from sliding out of its hole like i did. Hope this helps
kelvingenders
Post by kelvingenders » 07 Apr 2013 02:29 pm
Thanks. Took the central lockin component. Lots more access and quite easy to get in and out
