Hella wiring... Lost instructions... Help please
tattooer
Post by tattooer » 11 Oct 2013 06:58 pm
On the back of the grill is 1 brown and 1 greyish wire per light, I have a universal fitting kit and everything else, can someone break it down to retard steps for me please ;)
Re: Hella wiring... Lost instructions... Help please
Post by Ride_on » 11 Oct 2013 08:17 pm
You need to be a bit more specific, the standard lights are Hella, do you have a grill aux set? are these driving lights, in which case you would want them powered directly from a spare fuse via a relay triggered by the mainbeam lights.
tattooer
Post by tattooer » 11 Oct 2013 09:56 pm
My bad dude,
It's a hela grill, with fog lights built in,
I want these lights wired totally separate to all the other lights, on a switch included in the universal fitting kit
Post by macplaxton » 12 Oct 2013 09:58 am
tattooer wrote:My bad dude,
Are the actually fog lights or driving lights? I thought they were driving lights as they are too high for fog lights.
tattooer wrote:I want these lights wired totally separate to all the other lights, on a switch included in the universal fitting kit
Now if they are driving lights, you can do that, but the long arm of the law will give a ticket out if rumbled as driving lights should only come on with main beam.
I suggest you wire them in please the law and the MOT man - saves a lot of hassle.
tattooer
Post by tattooer » 12 Oct 2013 11:09 am
Aha, that makes sense...
Ok il do as I'm told!
Now... What wire goes where ;)
Post by macplaxton » 12 Oct 2013 11:34 am
Borrow one generic wiring diagram:
*Disconnect battery before starting work*
On you lamps:
Brown = earth/ground
Grey = +12V
Headlamp main beam wire = White/Blue
Does that make sense to you? So when the main beam circuit is on, the relay will close (switch on) and the power will get to the extra lights.
tattooer
Post by tattooer » 12 Oct 2013 12:30 pm
Ann that's exactly what I needed to know, thankyou very much :)
Post by macplaxton » 12 Oct 2013 12:42 pm
Report back later on success or fire! 340pw
tattooer
Post by tattooer » 15 Oct 2013 02:27 pm
No fire = total success :) thanks
Post by macplaxton » 15 Oct 2013 04:39 pm
340pw
Thanks for reporting back.
