urgent need of help !!
Hey guys I've recently fixed the plated for the shifter and it had been fine for a few months now and I'm now experiancing movement in what looks to be the ball joint in the selector the plate is still solid as but because if the extra movement in the ball joint it's makeing it harder to select gears anyone know how to fix this need to know asap
Re: urgent need of help !!
So there's play in the ball and it's not pulling the selector rod as far as it should be? Direct replacement would be the fix for this I would think.
So you've taken a part off your car, and it it's broken right? Replace that part.
