wiring. alternator no charge
Logan360
Post by Logan360 » 09 Dec 2013 08:11 am
Hey guys. In the middle of rust repairs0new engine prep etc and my 360 has no dash etc. Wanted to start it and keep motor good and running so plugged in:
All 4 fusebox plugs
computer
fuel pump lead (joins engine loom above heater)
Ignition.
now my fuel pump is on constantly
battery no charge.
not sure if the fuel pump is an issue but my main one is the no charging.
is there a loop circuit haven't connected for the alt?
what else could it be?
I don't has multi-meter so can't measure voltage or current flow.
any ideas?
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
Re: wiring. alternator no charge
Post by Ride_on » 10 Dec 2013 01:18 am
You need the dash light and bypass resistor to provide a little starting field current in the alternator. Try the manual circuit diagram and replicate the bypass resistor at the alternator. or you might be able to start it with a touch from the right wire.
Logan360
Post by Logan360 » 10 Dec 2013 01:29 am
Will plugging the instrument cluster back in help?
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Post by Ride_on » 13 Dec 2013 10:35 pm
Yes, the bulb and bypass resistor are in there.
Cliché Guevara
Post by Cliché Guevara » 22 Dec 2013 09:54 am
My 360 will run and charge with no cluster or jack.However the brushes on my altenator crapped out recently,remember that the original brushes will be getting on a bit 25 years or so.
Logan360
Post by Logan360 » 22 Dec 2013 11:44 pm
Plugged my cluster back in and she's fine now.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
