The fog lifts
Posted: 16 May 2014 06:19 pm
The fog lifts - or will do soon.
Evening girls,
Spending much time applying e-bay retail therapy, I recently came across a pair of 360 fog lamps which I duly gathered in.
I was expecting the usual "contained somewhere in a lump of mud" and the description accurately reflected the usual "fixing screw seized so edge of casing broken off".
Under the usual crud, and broken casing, and peeling yellow lens colour was a perfect reflector - the other unit, unbroken
was regrettably missing the "O" ring between the casing halves and over time had almost filled with mud! Needless to say the reflector was less than perfect (but surprisingly good considering)
All parts were cleaned and checked, the remainder of the yellow colouring removed, and a single perfect unit assembled.
This left the following to be solved before making up the pair.
Recover the reflector (solvent cleaning and touching up with reflective chrome paint).
Replace the casing "O" ring (big box in the attic).
Repair the main rear casing - I've no idea if the seller is a forum member here but if he is I will apologise for my gentle dig at his description of damage - "nothing a big washer won't solve"!
The damaged casing after cleaning,
A happy half hour with some 20gauge off cuts,
Trial fitting of the repair patch,
Patch treated with anti corrosion,
I'll put it all together tomorrow.
Mac.
Evening girls,
Mac.
