Hi,everybody! New on this forum.
I have problem with starting my car. At first sometimes the startengines solenoid klicka but the startengine did not work. I changed it to a new complete startengine but again the same problem. I got tired of it but after some days i set on the ignitionswitch and it sounds strange. Just like some misconduction in the switch... I changed it and at first it was working but later the solenoid began to klick again but it won't start. I heard from a Volvo-freind that there was some problems with overloading the ignitionswitch and therefor you could buy a relaykit to build in between the ignitionswitch and the solenoid. I will try that tomorrow... The most strange about it is that when I knock on the startengine with a hammer it usually works. Therefor I'm not really shure whether my problem is electical or mecanical...? I'm very thankful for tips!
Regards
Christer Nilsson
Sweden
Volvo 343 variomatic 1980, startingproblems
Re: Volvo 343 variomatic 1980, startingproblems
Hello and welcome.
start engine = starter motor.
MY80, starter motor was a "long case" type. The solenoid is either on the top, under the exhaust manifold, or on the side. The later cars, CH. 610000- use a slightly different motor (shorter and fatter). The later motor can be fitted, but I would personally use the older type.
I had problems with my motor, which I had to use a hammer on. Changed the motor and no further problems.
DSCF5606.JPG by macplaxton, on Flickr
Hello and thanks!
I also changed the starter motor and I think it is the short variant I got from the sparepartcompany...but should that really matter?
Short starter motor should be okay.
Check contacts / connections are good on solenoid.
Check earth strap connections are good.
