Wasted spark & tacho
Frits
Post by Frits » 16 Dec 2014 12:07 am
Anyone lucky getting it to work?
I tried the diode set up (what actually worked on a boa v6) and the tach fix (tach adapter) aswell the relais solution. No luck at all.
The revv counter actually works connected to one negative coil side (half speed).
360beast
Re: Wasted spark & tacho
Post by 360beast » 16 Dec 2014 11:39 am
Frits
Post by Frits » 16 Dec 2014 12:45 pm
And is he firing the original tacho?
Post by Ride_on » 18 Dec 2014 01:26 am
I've yet to do this but I believe the simple solution is to retain the original logic signal and single channel amp to work in paralell with the micro and dual channel amp.
Frits
Post by Frits » 29 Dec 2014 11:43 am
And how does this schematically look like? special parts used?
Post by Ride_on » 30 Dec 2014 01:28 pm
No special parts, I think the original circuit is wired to the original amp and the wasted spark pcb in paralell. Pretty much the original circuit to the tacho, but the coil is not needed.
