oli
Post
by oli » 19 Feb 2008 01:46 pm
Gents,
Quick question. How easy is it to replace front wings and doors?
Reason I ask is because I've seen a car and I know the front wing and drivers door is rusty (by the wing mirror) I wanted to know ho easy t is to replace these items? are the wings bolted on? what about doors? Just thinking if it's worth it if I did this or waited longer for a better one.
THanks
Man I must be getting close to owning one again...
Ronnie
Post
by Ronnie » 19 Feb 2008 01:59 pm
The wing is bolt on/off. Dead easy. Get some kind of sealant to bed in the new one, I forget what I used precisely. Be prepared for a shock when you se your inner wings though
Door pins are a bit of a b*tch to get out. You need a door pin removal tool. The Draper tool which is all over ebay doesn't have the right sized knurled nut, it's slightly too small and spreads the door pin, locking it, rather than driving it out. There's a spec for the right sized nut on here some where if you do a search for door pin removal tool.
oli
Post
by oli » 19 Feb 2008 02:31 pm
Ronnie wrote:The wing is bolt on/off. Dead easy. Get some kind of sealant to bed in the new one, I forget what I used precisely. Be prepared for a shock when you se your inner wings though
door pin as in the hinge pin? or fpr the locking mechanism?
Anyway front wing seems a nice simple job that I'm confident with not sure about the door and if its worth buying and having to sort when there are decent ones available if looked hard enough
thanks
Post
by filthyjohn » 19 Feb 2008 04:53 pm
Careful not to bend the wings when removing them, they're pretty well stuck on but you can get into the mastic with a blade and some solvent.
Ronnie
Post
by Ronnie » 19 Feb 2008 05:57 pm
oli wrote:door pin as in the hinge pin? or fpr the locking mechanism
Hinge pins
