revlimters...
Posted: 06 Jun 2009 06:01 pm
by Scottyj
Hello again people,
I don't think my 1.7 340 has a rev limiter, but is there anyway of getting a ignition cut or other rev limiter even though i have no ecu?
Cheers scott
Re: revlimters...
Posted: 06 Jun 2009 07:13 pm
by Jonofdoom
Ok so I'm an idiot with these kind of things so don't take my word for it, but i believe you can get rev limiters that sense your revs from the dizzy, and cut the spark at a given RPM... Again I'm not 100% on this, but I think that's one way of doing it in the aircooled VW world, where ECU's are quite unusual.
Although I must add I've only 74 posts on this forum, and at least %80 of them have been wrong:D
Re: revlimters...
Posted: 06 Jun 2009 07:33 pm
by volvosneverdie
im up to 86% failrate mate, so youre doing quite canny.
Re: revlimters...
Posted: 06 Jun 2009 07:47 pm
by Jonofdoom
Whey:D
Re: revlimters...
Posted: 06 Jun 2009 07:56 pm
by volvodspec
all ignitions used in 300 series can be equipped with rev limiters.
these aftermarket parts are usually attached to the coil + and coil - and have an extra wire for ground. adding a rev limiter can easaly be done on the older cars (343,345, early 340) because they have a loose coil. the later 300's equipped with the RENIX ignition systems can be equipped in similar way, though the coil + and - are a bit harder to properly connect the 2 wires to.
Re: revlimters...
Posted: 11 Jun 2009 11:53 pm
by Scottyj
Cool so can anyone point me in the direction of one or how to make one?
Its an 89 340 with a b172 lump...
Want ignition cut limiter or that kind of thing really, just mine screams and vibrates a lot high up and just want to set it low so i feel safe when giving it the beans..
Re: revlimters...
Posted: 12 Jun 2009 02:15 pm
by Scottyj
Re: revlimters...
Posted: 12 Jun 2009 03:20 pm
by Scottyj
right from what i can gather that limiter will work, will i need a single or dual coil?
Re: revlimters...
Posted: 12 Jun 2009 04:46 pm
by volvodspec
i have that omex unit with launch control
you need single coil.
Re: revlimters...
Posted: 12 Jun 2009 05:06 pm
by Scottyj
Cool worth it yeah? i dunno whether to bother with launch control or not... might just get the clubman..
How easy was it to fit?
Re: revlimters...
Posted: 24 Jun 2009 12:39 am
by Scottyj
just for reference i got a omex single coil and it was a piece of piss to fit, and works great..
