interior water leaks
mat_91
Post by mat_91 » 30 Mar 2010 10:28 am
well i think its coming up from underneath the dash on both sides
but i dont want to take out the dash and find its not that my door seal look in good condition
so im just asking if there is any common leaks that it could be and something to check first
thanks mat
Re: interior water leaks
Post by volvosneverdie » 30 Mar 2010 10:30 am
Base of the screen?
Heater vents?
mat_91
Post by mat_91 » 30 Mar 2010 11:02 am
i dont think its the heater vents as im not loosing any water
but with the base of the screen it could be but i would have to take out the dash to check
looks like i might any way just to check to see if theres any rust
Post by SteveP » 30 Mar 2010 11:20 am
Yep, sounds like corners of the screen to me
Post by Chris_C » 30 Mar 2010 11:49 am
I'd say corner of the screen too! Do your electrics play up per chance?
AJD
Post by AJD » 30 Mar 2010 03:30 pm
My 360 had a leak that came through the weather shield behind the interior door trim and then over the door seal. I was only able to find it by taking up the carpet and pouring water over the door/windscreen area. If it is still not obvious where it is coming from you could try dusting the floor pan with a bit of talc.
Alex
mat_91
Post by mat_91 » 30 Mar 2010 07:18 pm
yer ive had a good look today as im painting my inner wings and some of the bungs look a bit crap
so when its back together ill poor water over it and have a look its only a dribble that comes throu over a hole night
and then theres only a little bit in the foot well but i want to fix it
