stu_16v
Post
by stu_16v » 27 Aug 2009 10:18 pm
hi, what can i do? i mean what engines can i fit in which arent too tricky? its a 1.7 340.......lowered, locked diff etc....
common one is clio valver lump but that can get expensive when it comes to tuning it!
i have access to my mates workshop so got tools, welder.......etc
any ideas would be great ta
Post
by Speedy88 » 28 Aug 2009 02:09 am
Well my idea is to try out a williams clio lump but I'm not 100% yet. It appears to be simpler than 16v as well as cheaper to insure.
Post
by 340GLT » 28 Aug 2009 02:43 am
Williams clio lump is 16v......
Post
by volvosneverdie » 28 Aug 2009 06:58 am
Speedy88 wrote:Well my idea is to try out a williams clio lump but I'm not 100% yet. It appears to be simpler than 16v as well as cheaper to insure.
Yeah, Williams is just 200cc bigger than your run of the mill 1.8 16v engine.
It's the same swap though.
Post
by Speedy88 » 28 Aug 2009 02:46 pm
uh, 3am not good for speedy. I think I was on about the f3p or f4p
stu_16v
Post
by stu_16v » 28 Aug 2009 09:19 pm
yea dont fancy going down the road of valver lumps! girlfriend had a valver clio, ended up spending silly money on cams, verniers, re map etc.......
Post
by 340GLT » 28 Aug 2009 10:14 pm
I have a good B20 lump from a volvo 440 going spare........
stu_16v
Post
by stu_16v » 29 Aug 2009 08:37 am
you've always got goodies but your a million miles from me lol!!
Post
by classicswede » 29 Aug 2009 11:53 am
The 400 series 2ltr 8 valve lump is the mega easy swap. It does all just bolt in with no real modding required.
Bazboy
Post
by Bazboy » 29 Aug 2009 06:04 pm
Im guessing you still need the 1.7 stuff for the 400 series engine swaps?
Dan
Post
by classicswede » 29 Aug 2009 06:34 pm
If you are starting with a 1.4 then you will need the 1.7 bits
Post
by 340GLT » 29 Aug 2009 11:24 pm
I have those bits too!!!
Bazboy
Post
by Bazboy » 29 Aug 2009 11:29 pm
What engine options are there which would require the 1.4 stuff if any? apart from the r5 turbo.
Dan
Post
by 340GLT » 29 Aug 2009 11:34 pm
Gordini head and carbs.....
Post
by Speedy88 » 30 Aug 2009 12:24 am
Does the 400 2l have the same loom as the 1.7? Isn't it essentially the same as the 360 engine though? If not, does it have moar powaz?
