Here I am again with a little bit of an issue. My car had a bit of a trouble a few weeks ago with the fuel not getting to the carb, turned out to be a loose hose in the engine bay where the plastic tube enters in the engine bay and the rubber one goes on. Put everything back, the engine started up fine and ran great.
But now that we were getting temperatures of -15-20 C at night and in the day around -5 C the car wasn't really working that well. It was like it had been running on 3 cylinders so I took out the spark plugs and I noticed that it had carbon fouling on it. As you can see in the picture below:
I had another set, an old one which I cleaned up changed them over and the car was running brilliantly even in cold temps, until a few nights ago when it started to run on 3 again, losing all power, in neutral it was revs quite ok, went past 4000 rpm but in gear it wouldn't go just as last time I couldn't go over 50 km/h.
So I took out the spark plugs again and as I was expecting they were the same as the other ones that I took out before, all black and with fuel on them, they were wet.
I put them in cleaned as you can see in the picture the left one and the ones I took out were black as the right one on the picture:
Changed them again and the engine is working really nice...but I just don't know for how long.
My question is what can be causing this?
Too much fuel getting in and at low temperatures it wont vaporize as good as in above 0 C, so fuel is getting in the engine in more of a liquid form?
The engine is running nice when the plugs are clean, but I don't want to keep changing them every week
Any ideas on how to sort it out?
BTW the car is a 360 GLS with a B200K engine, everything is stock and standard.
Cheers,
Arpi
