gearbox&diff
Joe
gearbox&diff
Post by Joe » 20 Apr 2010 05:13 pm
I have just blow my diff up and need a new one because i have a drag race in 12 days!!! I got offerd a 5 speed gearbox and diff cheap, but the only problem is my car had a 4 speed gearbox in and i was wondering if the 5 speed would fit in ? Cheers Joe
Roll like its your last time and just let the good times roll
Foook power grow some balls and get commited :)
Re: gearbox&diff
Post by SteveP » 20 Apr 2010 07:36 pm
It'll go right in yes, you'll want to swap the whole transaxle which is sounds like you were going to do
Joe
Re: gearbox&diff
Post by Joe » 20 Apr 2010 08:02 pm
Cheers bud, i have just finished rebuilding my gtt engine in one night :)
Re: gearbox&diff
Post by SteveP » 20 Apr 2010 08:10 pm
Good effort!! The 4 speed diff has a longer casing, so the units are the same length... therefore pretty sure the prop is will be fine on the 5 speed box too. This is what I found out when I wanted to do a 5 speed conversion on my 343
Joe
Re: gearbox&diff
Post by Joe » 20 Apr 2010 09:05 pm
Yer, i measured the hole centers and they are the same but the is like a big chunk off bar were the prop goes onto it looks like ots there to act as a balance is this normal?
Re: gearbox&diff
Post by 340GLT » 20 Apr 2010 10:16 pm
If the box is out of a 1.7 then it has a harmonic balencer on the front of the gearbox.
Joe
Re: gearbox&diff
Post by Joe » 21 Apr 2010 05:33 pm
Yer that must off been it.
