Crank Shaft sensor
volvobob
Crank Shaft sensor
Post by volvobob » 25 Mar 2011 01:39 pm
quick question, basiclly does the 4 speed gearbox have a crank shaft sensor ?
Re: Crank Shaft sensor
Post by Ride_on » 28 Mar 2011 12:40 pm
The gearbox does not have a crank shaft :) Presume you mean the 4 speed models, but yes it depends on the engine not the gearbox. All later 300s with the renix/bendix computer ignition (module with the built in coil+vacuum sensor) use a flywheel sensor. Approx 1984 on I think.
