B230fk converted 360 over heating problem
wiganer31
Post by wiganer31 » 04 Sep 2012 01:13 pm
Hi as alot will know i converted my 360 to a b230fk, its running good and working threw the problems as i go along, the main one i really need to sort now is the over heating problem. Im not running a intercooler atm due to room and it still running standard boost, reason theres no room for a cooler is because im running two big fans dje to the cooling issue, ive tryed running it on about 80 percent coolant but was still the same, at the last drift event i whent to i was going on track twice and then comeing off to let it cool down and that was with no bonnet on, im running the 360 rad as the one on my 940 was anit fucked and dosnt really fit but dont think it should make that much differnce. Its stipp pretty high on the motoway, anyone got any ideas or had this problem?
Re: B230fk converted 360 over heating problem
Post by volvodspec » 04 Sep 2012 01:43 pm
How have you plumped in the turbo to the watercooling systrm?
wiganer31
Post by wiganer31 » 04 Sep 2012 02:03 pm
Yea mate, ive been wondering if its cooling the turbo properly
wiganer31
Post by wiganer31 » 04 Sep 2012 05:48 pm
Just done something silly while doing a few bits on the car, pulled all the pipes off without lookint were they go properly, think ive got them back as they should go, will post up some pics for help lol
wiganer31
Post by wiganer31 » 04 Sep 2012 11:38 pm
Heres a few pics, anyone know if i put them back as they should be lol, remember im useing the 360 rad and header tank
These are the fans, plenty enough air being pushed threw the radImage
O im running no thermostat atm and makes no differnce
Fuse
Post by Fuse » 05 Sep 2012 08:04 am
The water hose from turbo which you have now plumbed in to the top port of overflow reservoir is originally plumbed with a t-piece in to the hose which goes from the radiator to the lower port of the expansion tank. It's generally not a good thing to plumb anything above the expansion tank (except the original air hose from the top of the radiator) as it very easily creates air locks in the cooling system, especially when it's plumbed "in air". Also the turbo watercooling is designed to work in such way that the water flows through the turbo by the convection even when the engine is shut off, it won't work as designed if other end is in free air.
Turbo water cooling doesn't affect engine or underhood temps otherwise, it's there to cool the bearing housing after you have shut off the engine.
Also I'd install a thermostat at once. Lower temp thermostat if needed, but it's a bad thing not to have a thermostat at all.
Running a redblock engine without a thermostat usually makes things worse temp wise as there is a bypass channel from the thermostat housing to the water pump, which the thermostat closes when opening.
If you don't have a thermostat at all, this bypass channel is always open and quite a large amount of water might not flow through the radiator at all!
Bypass channel and the way it works can be seen at this pic.
If temps still rise when the turbo watercooling is plumbed correctly, you have a thermostat in place and the system is air-free, I'd check the radiator and the water pump as there really aren't any other possibilities left if everything else is in order.
-Marko
Post by Ride_on » 06 Sep 2012 12:40 am
There is nothing special about the B230FK against the 360 cooling. The 940 has Al+plastic rad and the 360 is steel, otherwise same circulation and water pump, with minor addition of the turbo cooling mainly by gravity in the expansion tank. The small 940 rad I have (manual/non-AC) looks about the same area as the 360, see photos about weight comparision. The bigger ones are for AC mainly.
There should be plenty of cooling capacity, the 940 can manage with 1/2 full system, no fan etc, same as the 360 (I've abused both).
Most likely it is a simple problem:
-Not enough air flow - why are you not using the 360 water pump and vicsous fan+cowling?
-Not enough water flow - is the pump broken(damaged blades)? try running the engine warm with the top pipe off the rad and checking there is plenty of water comming out (put a water feed hose in the expansion tank) . Maybe the thermostat was fkd and taking it out completly fkd things in a different way.
wiganer31
Post by wiganer31 » 09 Sep 2012 08:07 pm
thanks for the help guys i realise what i have done now :oops: ive now got it plumbed in correct now and took it for a test drive to get a new thermostat and it seemed alot better,
problem is though i fitted the new thermostat and topped it up, ran the car up to temp but the water level didnt drop even though most of the water had come out while fitting the stat, gave all the pipes a good squeeze and got a few air bubbled comeing up into the tank but water hardly whent down atall, temp whent up to over three quaters but nothing, heater matrix and rad were both warmed up, ive no idea, anyone?
Post by classicswede » 09 Sep 2012 08:13 pm
Disconnect one of the heater hoses, fill with water till the water starts coming out of the hose then push the pipe back on. Fill to top - start engine and then when water starts leaking from hose joint tighten clip. That is a good way that works for me getter air out of the water system.
Where is your intercooler?
mac
Post by mac » 09 Sep 2012 09:14 pm
This probably sounds a stupid question but are you sure you are actually overheating ?
Are you relying only on the dash temp gauge or do you have a thermocouple in the system ?
What symptoms do you have ? - it's not unknown for temp sensor (gauge sensor is separate
from LH sensor) to show overtemp when engine is not really overheating.
Is the overtemp confined to the block/head or is the rad too hot as well ? If the engine
has not had antifreeze changes over the years it's possible the waterways have become silted.
Has the impeller come off the h2o pump shaft ? Forget turbo cooling - lack off won't raise
overall eng. temp by any degree.
These engines really don't have overheating problems - if anything they will run a little cool
even on the hottest of days.
Mac.
wiganer31
Post by wiganer31 » 09 Sep 2012 09:19 pm
cheers mate will try it, i got told something similar to that to that but with the engine running, but didnt fancy doing it with a hot engine lol, will try it how you said,
not running a cooler yet, once ive sorted the cooling out i will buy some proper fans to mount on the other side of the rad then i will have plenty room to mount a decent size intercooler, i know its not ideal as it is but its running standard boost and seems to run ok atm, hopeing it will be ok for now
wiganer31
Post by wiganer31 » 09 Sep 2012 09:24 pm
dont sound stupid mac i know what you mean,
it is actually over heating but not every time, the temp gauge dosent seem to be to far out but going to get a after market one to make sure,
had the steam comeing up from the bonnet and water spilling out etc, the rad dose get pretty hot to,
i will get it bleed up proper with the new stat in and if theres no change im going to start looking into the water pump, hopeing its started soon as its costing me a fortune in antifreeze lol
Fuse
Post by Fuse » 09 Sep 2012 11:08 pm
And change that turbo water cooling because like I wrote it can cause serious air locks if it's connected like that. ;)
wiganer31
Post by wiganer31 » 10 Sep 2012 01:51 pm
Fuse wrote:And change that turbo water cooling because like I wrote it can cause serious air locks if it's connected like that. ;)
as i said i now have it plumbed in correct now?
Post by Ride_on » 12 Sep 2012 10:56 pm
So the temperature is not consistent? Its rising up under power and dropping at tickover?
If so its definately overheating.
I was thinking about the 360 gauge on a 940 sensor, it probably won't match. The engines run at significantly different temps (87 and 92 (360), possibly enough to register 3/4, an 88 thermostat gives a visibly higher indication on a 940), although I don't know if the gauge is different or the sensor is different so hard to say what way it will go. But thats just on the non-overheating theory.
If it is still over heating, you do not have enough water flow (assuming its rising when the car is moving which should be enough air flow). Definate should check the pump flow by the method I mention above. I wonder can you see or feel the pump vanes with your fingers from the side inlet (take the fan belt off and turn the pump).
Another test you could do is attach a garden hose to the inlet (seal it with you hand or something) and see it comes out the other side under pressure. This should check for blockages.
Actually re-reading, you say the rad is quite hot, if there is no water flow it should not really. Could you be creating too much heat? cam timing off?
