PISTONMELTER5
Post
by PISTONMELTER5 » 06 Dec 2012 09:02 pm
Is it the front or rear s14 coilovers you use to convert the front of the volvo to coilover suspension?
been looking through a few threads and have seen a one say front and the other say rear
What exactly needs doing to convert them? is it just a matter of grinding down and welding the s14 ones to the volvo hub?
any clarification would be appreciated!
Post
by classicswede » 06 Dec 2012 09:18 pm
In short you dont.
When converting to coil overs you can use the nissan top mount
PISTONMELTER5
Post
by PISTONMELTER5 » 09 Dec 2012 08:08 pm
what i was planning was to use the s14 coilover itself! As a mate has a set cheap i was planning on machining out the steering knuckle ever so slightly so that the s14 coilover fits into it and then weld it up so its all nice and secure, was then going to extend the original strut tops by about 2 inches so ive a good bit of adjustability and then redrill it to fit the s14 top mount bolt pattern as you would have to do anyway when extending the turrets
Attack2001
Post
by Attack2001 » 13 Dec 2012 09:41 pm
PISTONMELTER5 wrote:what i was planning was to use the s14 coilover itself! As a mate has a set cheap i was planning on machining out the steering knuckle ever so slightly so that the s14 coilover fits into it and then weld it up so its all nice and secure, was then going to extend the original strut tops by about 2 inches so ive a good bit of adjustability and then redrill it to fit the s14 top mount bolt pattern as you would have to do anyway when extending the turrets
Search nikdev, i remember him using a set of s body coilovers in his 300
Thomas...........
