360 LSD.
Re: 360 LSD.
Post by Ride_on »
My build is documented earlier in the thread with all the photos. I used new bearings and they seemed to be ok, 'good level of stiff', I didn't look at the backlash, there maybe a little. Don't know how that would sieze the internals though.
To be clear, my diff is not unlocking I cannot move the wheels differentially by hand.
Where would you get shims that fit in varying size? These are big ones on the outside?
Re: 360 LSD.
Post by Ride_on »
Well I've made some progress after removing the internals from the casing.
Removed the end cap bolts and found they where too long having bound up at the end, and reverse engineering the torque was only 20-23nm. The end cap wouldn't budge and I didn't want to damage it by hammering. However the diff was still locked. I may cut these down, but would be useful to know the correct torque.
Removing the crowheel bolts unlocked the diff and it was possible to counter-rotate the flanges (put in again after removing from the casing). In fact they move pretty freely. Tightened them up again to an intermediate torque, still free. Only when using the full torque (90nm) does it lock up solid.
I found the 90nm figure by reverse engineering the originals. I marked them, lossened, then tighened up measuring the torque to get the marks aligned. To get this tight I needed a special technique to hold it (shown in the build pictures).
Nimmiz, did you use a specific torque or just whatever you could manage? I've tried contacting the other buyers but so far 2 have said they havn't fitted them.
I might try slightly a lower torque, but really it should take the OE torque.
Re: 360 LSD.
Post by Ride_on »
Just reread my build thread and noticed the diff was locked then too. I guess I assumed it was correct it would be stiff but actually the diff should be loose and it should be possible to turn the wheels by hand in opposite directions the same as a normal diff. According to what I've read a Torsen will only transfer torque when there is some so hand moving them should not cause any locking.
360beast
Re: 360 LSD.
Post by 360beast »
At least you know for sure there is a problem with the diff and now it just a case of finding out what, good luck.
Re: 360 LSD.
Post by Ride_on »
Yeah well making progress.
Some other thoughts
The new module was difficult to install to the crownwheel and heat was needed (oven at 180)
Perhaps the mating faces are not flush
Seems like the module casing is distorting on the application of the full bolt torque
Nothing to do with crown backlash, this is out of the outer casing.
One theory is that with the crown being too tight a fit it is distorting the casing on full bolt torque, this could be caused by measuring for fit rather than designing (therefore needing Volvo's measurement and tolerance). Possibly a trim on a lathe might sort it.
Will try lower torques tonight, but I think anything <70nm would not be desirable. Will also try and resettle the module in the crown if I can get it apart again.. oven time. Maybe some washers to replace the crown and/or to space the bolt out a little and keep out of the weak thread area.
Re: 360 LSD.
Post by Ride_on »
Looks like the diff module is not sitting flat on the crownwheel. In the process of cooking it now to remove (hopefully), then see whats going on.
I'm measuring 15.6mm in one of the blind holes to 16.1mm in the other (back of crown to base of diff module). The 0.5mm difference!
Internals with flanges loosely in.
Flush at the bottom
Flush at the bottom
0.5mm more at the bottom
Re: 360 LSD.
Post by Ride_on »
Deeper in now but not there yet.
The diff module is the same size as best I can measure as the Volvo cage, although the edge is a little damaged.
The deeper reason for the problem is that (in my case at least) the insert for the crown wheel lifts the mating surface of the module and leaves a gap between the 2 parts around the bolts. The base of the diff module is full of (purposful) holes and quite weak to the bolt torque bending the outside edge against this insert.
The insert (came with the diff) is very smooth and the helical gears rotate against it halfway across the insert outside egde. It maybe designed to suck oil from the gap or not rotate against the less smooth mating surface of the crown wheel.
gap in bolt area
gap in bolt area
Either;
1. The insert is too high and needs shaved down or
2. Its not flush for some reason or
3. It is designed this way and a much lower torque is needed or
4. I need to shim the mating surface around the bolt holes and close the gap
Re: 360 LSD.
Post by Ride_on »
Tonights exciting installment is that I think I have the problem.
After getting my heat assembled insert out with a newly invented technique due to lack of liquid N, some measurements indicate more of the story.
The insert seems to be designed to be flush with the surface, the lower step is shorter than the crown so cannot bottom out leaving a gap and the top step seems to be within 0.05mm heightwise as best I can measure. The problem seems to be the outer diameter that is 77.3mm when the hole in the crownwheel is 77.0. The corners look ok (ie not interfering) but its hard to be sure.
So my solution would seem to be to trim down this outer dia by 0.2-0.3mm. This is stopping my diff module bedding down on the crownwheel properly.
Atchi, is it possible to check the drawing or with the mfr to see what it should be. Do I have an out of spec part? Is the design intent to be flush? Is it meant to be an interference fit?
Please note my measurements are only reliable when considered relatively. I can get a more calibrated absolute measurement in work if necessary.
Insert and crownwheel
Re: 360 LSD.
Post by Ride_on »
Not much progress today but one of the other guys who hadn't fitted theirs also had similar measurment with 0.2 over on the insert diameter. They also had the main unit over-sized by 0.2.
If the tolerances need to be tight you need to measure a number of OE units to determine the actual manufacturers specification otherwise its a fettle-fit and its possible the mfr intended this.
Sounds like you need a machine shop to fit this, not quite a straight swap unfortunately.
perkabrod
Re: 360 LSD.
Post by perkabrod »
I took my diff to a machine shop and they remove approx 2/10 mm from the diff housing in order to fit in the crown wheel.
Still haven't dealt with the small distance plate, it is slightly too large in diameter, and maybe that's also why it doesn't sit flush when I put it inside the center of the crown wheel
Re: 360 LSD.
Post by Ride_on »
Yes thats what I'm saying. When I measure the depth of steps on the insert and in the crown, it seems to be designed to be flush, its just the big diameter thats slightly over-size.
The diff doesn't work when the insert is not flush (after the crown bolts are tightened), its just completely locked like a welded diff.
The insert seems to have 2 functions
1. To hold/centre the output shaft gear.
2. To support the end of the helical gears
miniswift
Re: 360 LSD.
Post by miniswift »
Hi,
I have sent last photo to the guy who made it for me.
So please bear with me.
Atchi
Re: 360 LSD.
Post by Ride_on »
Cool, ideally we also need to know;
1. What sort of fit is needed for the insert and diff module to the crown - interference, tight, snug, clearance?
2. Is the insert expected to be flush? If so what spec? +0 to +0.05mm?
3. Expected Torques for crown bolts and diff module end cap (90nm and 23nm?)
for the rest Volvo specs should be relevant.
I'm trying to collect a number of bearing shims at the moment, we may need to exchange thickness information or combine our spares. Worse case get some laser cut.
Re: 360 LSD.
Post by Ride_on »
Just reading up on the green book which was pointed out in the resources sections. Lots of useful info
Part numbers and rules of thumb for bearing shim calcs
Torques for crownwheen bolts - 137Nm (M12x1.25 bolts)
Torques and locking for bearing retainer bolts
Specs on backlash and how to change the shims.
And how you can never ever change the pinion, well without the right tools and new parts.
So you need shims to get the bearing pre-load, then you might need to change them again for the backlash. Not sure how to measure the bearing pre-load with the pinion in, hopefully backlash is big enough. Need a shim kit!
Re: 360 LSD.
Post by volvodspec »
my 343 is also equipped with one of these, no problems on assembly and a perfectly working LSD
