340 1.4 engine change ?
Hi guys is there any lump I can drop straight into the 340 1.4 without much hassle or turbo options cheers
Re: 340 1.4 engine change ?
Renault 5 turbo.
With 1.7 parts Renault F4R, F7P, F7R
Some people even turbo the original engine but you would need to lower the compression.
Sorry to bring back a old thread but I have a volvo 340 1.7 swapped to a F7R, I know a 1.4 340 can take a 360 power steering rack my question is,
Would I be able to buy a 1.4 340 convert it to power steering then drop my F7R into it? im not sure if the steering rack will get in the way of eanything
Well, I want to know the same.
Or would it be easier to get another 1.7 and try and fit power steering to it? If thats even possible because I already have the mounts and everything in my donor car.
Cheers Rob
Cheers Rob
I would be surprised if the rack did foul on anything.
Cheers I shall try it once I get a new 340, hopefully once I come back from my holiday and have some spare cash.
What I remember and you will find if you search the forum is that to fit the PAS rack to a 1.7 you need to raise the engine a little.
If that needs to be done you are going to need also ajust the gearbox position to keep perfect prop alignment
