Post
by bogbasic » 30 Nov 2020 02:20 am
Another 3 days and its holding up nicely. Battery re-charged for Tuesday.
Hope this bodes well.
Post
by SteveP » 30 Nov 2020 10:56 pm
Good sign!
Post
by bogbasic » 02 Dec 2020 10:23 pm
Right, bits of news. There was a big drop in the fuel level over the last couple of days...
... worrying, but the car started, which is good, so took it for a drive but after 30 min the ignition just died ;-0 arf (not on a main road, thankfully). It was a case of wiggling the connections on the back of the fuse box, so we are back in that game again. Will need to remove the fusebox and clean the connections, etc. The new rear exhaust section is knocking like the clappers so that will need removing, hammering in and refitting. The renix 407 seems good but the idle speed is not right (1100) so that will need a look at, too.
So it's back to the 1.7, for a bit anyway.
Post
by bogbasic » 17 Dec 2020 12:44 am
Post
by bogbasic » 17 Dec 2020 06:02 pm
Post
by SteveP » 18 Dec 2020 11:36 am
Good news! Definitely worth fitting new clips to that fuel tank hose, I fitted new stainless ones when I had my tank out - the originals do like to disintegrate!
Post
by bogbasic » 04 Jan 2021 02:23 am
Not quite fit-and-forget since the car had an occassional issue of idling too fast (2000 rpm) which I couldn't easily sort out. I had noticed that the problem was due to the plunger at the side of the carb (which is to do with float chamber ventilation) kept getting pulled into the down position by the plastic lever. However, a couple of hours fiddling about revealed that it had a *very* simple cause - the choke cable had become a bit bent in all the previous shenanigans and was not allowing the carbie cams and levers to go fully back to ground-zero when the choke was pushed in. However, after a bit of straightening, I can sleep peacefully now.
And, the starting is OK, too.
