Clutch Adjustment?
Nevesy
Clutch Adjustment?
Post by Nevesy » 06 Oct 2007 09:56 pm
Hello
Is there anyway that you can adjust the clutch, the biting point on mine is really high up and I have my knees around my head before I get going anywhere.
Thanks
Post by classicswede » 06 Oct 2007 09:59 pm
Two 10mm spanners. Take a look on the pass side of the bellhousing and its under the rubber boot.
Nevesy
Post by Nevesy » 06 Oct 2007 10:08 pm
Do you have any pictures of where they are located please :) .
Post by classicswede » 07 Oct 2007 11:52 am
I dont have a pciture of it sorry but it is down this side
If you look down by where the engine mates to the bellhousing you should see it.
The other way would be to follow the cable from where it comes out the bulkhead on the drivers side. If you trace the cable along it goes forward onto the crossbar and then back around the other side to the clutch fork.
Nevesy
Post by Nevesy » 07 Oct 2007 05:06 pm
Found it thanks :) , which way do I turn them though, turned each way and then tried the clutch and didnt seem to make much diffrence. I also have another problem which someone could probally help me with, the central locking stopped working all of a sudden, tried the fuses and they are fine, thought it would be better to ask in here rather than starting a new thread :roll: .
