Steelballz
Post
by Steelballz » 12 Mar 2009 02:00 pm
lads, found a goldmine (i think) at the local mechanic's, a 940 (or 960, not sure lol)...and its got a 2.2 or 2.3 turbo petrol engine, again not sure which it is but fairly sure where I gave it a quick glance the taxdisc said 2.2....
I did a bit of research on the interweb, and this one seemed the most appropriate out of the engine list...
"B230FK: 2.3 L inline-4, turbocharged, Low Pressure Turbo ('95-)"
if thats it, is it a good engine..?(ie will it take kindly enough to a welded diff and a bit of "fun"???)
btw, where do I find the engine code on a volvo (ie where on the block exactly), sorry for the stupid question...
Fuse
Post
by Fuse » 12 Mar 2009 08:47 pm
That is one of the best redblocks there are because it's late model (FK's always are) so it has strong 13mm conrods so with good tune stock bottom end can handle +400hp, it probably also has oil squirters for pistons too which is a good thing.
So yeah it is a good engine.
Post
by classicswede » 13 Mar 2009 11:22 pm
The engine code is on the cam belt cover.
Steelballz
Post
by Steelballz » 16 Mar 2009 02:42 am
Hmm, saw no engine code there the last day...
I'll try and organise some pictures one of these days (maybe even tomorrow), and then someone may be able to give concrete info about it...?
Steelballz
Post
by Steelballz » 26 Mar 2009 01:55 pm
ok, have the engine code.
and it is indeed the B230FK, and for €250 I'm fairly happy to get such a car.now just got to sort out some diffin wheels, and lots and lots of tyres
:D:D
Post
by SteveP » 26 Mar 2009 03:29 pm
Yep that's a good engine for tuning that, low boost but either the HPT actuator or MBC and 12psi will sort that. Thicker 13mm conrods and oil squirters too!
Post
by classicswede » 26 Mar 2009 07:06 pm
Crank up the boost
Steelballz
Post
by Steelballz » 28 Mar 2009 01:27 am
@classicswede AND SteveP:
I would, but for a €250 "messing-car" I dont wanna spend money on an adjustable actuator...(or bent the rod of the standard one either...)
Post
by SteveP » 28 Mar 2009 06:25 pm
I just meant an actuator off a HPT car.. which will basically be free under £10 from a breaker! Manual Boost Controller for about £40, well worth the expense for the gains!!
xtrmjks
Post
by xtrmjks » 28 Mar 2009 09:03 pm
SteveP wrote:I just meant an actuator off a HPT car.. which will basically be free under £10 from a breaker! Manual Boost Controller for about £40, well worth the expense for the gains!!
Bleed valve on actuator pipe, anyone?
Steelballz
Post
by Steelballz » 31 Mar 2009 12:59 pm
"HPT" car?? please explain, I'm simple LOL
xtrmjks wrote:Bleed valve on actuator pipe, anyone?
and you also explain where I am to put a bleed valve, and why...does it actually up the boost...??
Post
by filthyjohn » 31 Mar 2009 01:07 pm
Steelballz wrote:"HPT" car?? please explain, I'm simple LOL
High Pressure Turbo. There were two versions of the engine, one was restricted. By fitting the higher pressure actuator you'd have the power of an HPT.
Steelballz wrote:and you also explain where I am to put a bleed valve, and why...does it actually up the boost...??
The wastegate of the turbo opens when a certain boost pressure is reached. There is a pressure feed to the wastegate actuator to 'tell it when to open'. By fitting a bleed valve you allow air to escape, reducing the pressure that the actuator sees, delaying the opening of the wastegate and increasing the maximum boost pressure.
HTH
Steelballz
Post
by Steelballz » 07 Apr 2009 01:52 am
filthyjohn wrote:Steelballz wrote:"HPT" car?? please explain, I'm simple LOL
HTH
hmm, I'd probably choose the HPT actuator then......But how do I know which one my engine is, as the link in my forst post is what wikipedia told me...So I'm unsure if mine's the low or high pressure turbo, can it be told from the B230FK engine code, or what..?
Jason B
Post
by Jason B » 07 Apr 2009 09:18 am
your b230fk will be a low boost pressure variant of the b230 and has a td04-13c turbo on it iirc, the boost ought to be at 4psi stock and you should be able to carefully raise that to 12psi-ish as the block is exactly the same (and most other bits I think, haven't looked into turbos engines for a while!!), in fact I think the whole engine is exactly the same as a b230ft just running @ 4psi instead of HPT boost levels. -Though you should check this as I'm not 100% sure and can't be bothered to check it myself
Jason B on 07 Apr 2009 07:29 pm, edited 1 time in total.
Post
by SteveP » 07 Apr 2009 02:56 pm
B230FK is 3.5psi IIRC
You may even be able to run 14psi with super unleaded
