any ones car suffering from the damp ?
Post by pettaw » 07 Jan 2006 12:59 am
I've had that happen twice, the carbon brush got pushed right up into the cap and jammed up there. The cars were running pretty good too, surprisingly :o
Post by redline » 07 Jan 2006 11:14 am
foggyjames wrote:Was it oily at all Mick? Redblocks with head mount dizzys are famous for the rear cam oil seal failing, causing oil to pour into the distributor...same thing could apply to the F2n I guess?cheers
deffinately no oil but a bit of condensation in the cap
seems fine so far with the new one ,
Post by petefarrell360 » 13 Jan 2006 03:32 am
Been meaning to post Mick, it's not just the B172 that's been affected by the damp in Bucks, the B200E has gradually been affected by it too. I mentioned to Andy how it was not running right the other morning, in 4th you could feel the power pulsating, a bit like hitting a nasty pothole on acceleration, the no power, woah power, then nothing then lerch, here we go! It was mis-firing until it warmed up.
Thurs morning it ran like a pig, started okish, thought I'd leave it running to defrost, but after about 10 seconds it started coughing and spluttering and nearly died, but caught it with some throttle, but then it got worse and worse. Gave up for five mins, deiced it with a scraper, aka RAC card. Restarted and set off at snails pace, as it warmed up things improved and within about 3 mins of driving things were fine. So, after talking to Andy, I'll be changing the distributor cap and leads, check the plugs and see how I go! Mick, you're not alone.
However over the last couple of days, I've noticed an intermittent noise, which I am sure if the fuel pump, (it was present Thurs when it was running rough, and also before when it was running ok, but it was cold and damp at the time) it's not the buzzing it makes when it's really hot in summer, but a lowish pitched hum.
