1.4 only running on 3 cylinders
Could be, but it seems very complicated to check, and i don't have a strobe lamp
But the timing is probably off, better fix it.
Anyway. Today i changed all the plugs once again, this time to NGK BPR6ES plugs, which are supposed to be good. The ones that were in there were cheap-o-rama's (Eyquem or something).
Also i replaced the ground wire on the renix since it measured 7 ohms or so. Now i have a 0 ohm ground connection as i should have. All the other tests in the green book seems to be okay except for the timing test (don't have the equipment).
It runs a little better and smoother now. Sometimes it actually runs really smooth for 2 seconds then back to shaking and "putt"-"putt"-ing.
If i apply throttle up to about 1500rpm and so and yank the plug that don't work at idle then it runs a lot worse, so it seems to ignite okay at speeds above 1500 or so.
I don't know if this might be due to some problem (dirt?) with the flywheel sensor (what does this actually do?) or the flywheel? Or maybe something with the vacuum to the renix?
Anyway I am replacing the clutch so I'll look at the flywheel and sensor really soon to see if there's something there that might need to be cleaned or whatever - does the renix get timing information from the flywheel?
I've always found acess better on the 360.
The fact that the missfire is worse at idle to me indicates an air leak rather than ignition problem.
Yes, at least in Mk3 it is quite ok to access, two bolts and then just pull it out, don't know how it is different in 340, but I would think it is similar job.classicswede wrote:I've always found acess better on the 360.
Is carb base warped, or did that happen on 1.4 too?
To check that one needs to remove carb, check with ruler surface that is against manifold, it should be absolutely straight so that there is no gap at all when checked with ruler.
Well i think my sensor is just fine. It looked clean, and measures 222 ohms with an ohmmeter (spec says 220 ohms +/- 60). It's just a black plastic cylinder with a very small protruding tip right? Nothing more?
I think the problem might be an air leak like classicswede says. Gonna change every hose, air/fuel filter, new exhaust from the manifold and recondition the carb and see how she goes.
... edit
And I just played around trying to find vaccum leaks and i think there might be a leak where the carb meets the intake manifold. The area around the two bolts nearest the rocker cover is kinda wet. Also spraying WD-40 or similar here revs the engine up.
In addition the studs to mount the carb here was loose giving me a hard time getting the mounting nuts off. So that's probably why it's been sucking false air. The gasket seems fine.
I'm gonna try taking the studs out and putting epoxy steel down the holes and screw the studs back in and see how it goes. I'm having a hard time cleaning the outside of the carb as the side where the gas hose goes in is packed in greasy dirt (used to leak around the gas inlet). If anyone has any tips on getting this crap off please let me know.
... edit
According to Haynes the float height should be 7mm from bottom of float to top of gasket when holding the lid upside down, but green book says 22.7mm from float centre to mating face of lid. Are these pretty much the same?
I replaced the float, needle and seat and stock it's at 7mm from bottom to gasket, which is what haynes says, so i guess it's okay stock then?
And getting the choke lever back on with the spring correctly is impossible
Any tips?
Yes, very tight. I also replaced the gasket on it.morgan105 wrote:Is the base plate tight to the bottom of the carb? Screws are located underneath the base to the carb and can come loose and are easily overlooked. And are all the vacuum hoses clean and securely connected?
morgan105
All the hoses are new with new clips except the renix one, but if i plug the hole to the renix on the carb with my finger and spray carb cleaner it still revs up, so i guess the leak isn't there.
I think the manifold may be leaking, it's pretty much the only thing i haven't tried to tighten the nuts on. Long shot but i guess it's possible.
