pistonpen paultje
Post
by pistonpen paultje » 05 Mar 2008 12:23 pm
Untherneath the rearseat the MK2/3 have a more flat surface(hmm doubting MK2 1.4 now...), so a 360tank fits underneath the body. MK1 1.4's gets deeper near the side. Ive only seen one B19 MK1. But didn't look to close. This week i'll see one probably (maybe even buy it) . So im going to check that.
voly340
Post
by voly340 » 16 Mar 2008 03:27 pm
this could possibly be stupid but....
couldnt you just use the clio fuel pump and lines if your running the injectors?
kaos
Post
by kaos » 17 Mar 2008 09:30 pm
because its a 6mm return and 8mm feed, you need to at least change the intank set up to allow those outputs. or use an inside based alloy fuel tank etc
voly340
Post
by voly340 » 30 Mar 2008 08:36 pm
if your using a swirl pot, couldnt you use the standard pump to just supply the pot from the main tank, then use a clio pump or similar to supply the injectors? providing the you have a swirl pot that has the correct size connection for the different diameter hoses of course?
Post
by Chris_C » 30 Mar 2008 11:14 pm
That would be idle mate, but stock 1.4/1.7 pump is mechnical off the cam. LP electric pumps of the capacity are all over the bay cheap though.
ANTEQ
Post
by ANTEQ » 06 Apr 2008 08:17 am
