Page 1 of 4
Same old B14 VArio running probs (again)
Posted: 23 Jul 2010 04:56 pm
by volvosneverdie
The cars developed more pressing problems.
Now this has only happened on the last quarter of a 15ish mile journey (there AND back) today.
Symptoms:
In pressing the accelerator when cruising, nothing immediatly happens. Theres a pause, then theres a surge of power (accelerator held steady), then power drops, then surges. This carries on unless you really gun it. Really gunning it brings stready acceleration. Untill you back off.
Theres a sound from somewhere underneath that John recons sounds like the bellhouse bearing being fooked. (again, this sound only manifests after 20-30 mins running.
The car is hard to start from warm and withought throttle, will die immediatly.
Seemed to struggle at junctions, a LITTLE bit, but never stalled on the road. Only when I got to destination, turned ignition off and tried to restart.
Might be worth noting its very hot today.
Got a long journey planned tomorow.
Anyone have any Ideas?
Vacuum leak?
Ignition?
Gonna check the ignition bits I can tonight, could do with advice on how to find and remedy a leek, if thats what it is?
Re: B14 Vario problems
Posted: 27 Jul 2010 06:20 pm
by pyro
volvosneverdie wrote: remedy leek,
other than that im no help at all
i could suggest somthings but it would probably be wrong.
so i wont
Ben
Posted: 27 Jul 2010 06:23 pm
by volvosneverdie
Cheers dude.
Posted: 27 Jul 2010 10:58 pm
by pyro
I aim to please!!
doesnt always work mind
IN all fairness, spray some easystart round and pipes that look sketchy and listen for any chance in engine note.
the jerking under acceleration could be carb float, or float valve sticking.
though if the 340 has a centrifugal clutch that could well be suspect as it may give the sounds you desicribe. the jerking being the weights/friction pads engaging, then not with the clutch housing OR thinking aloud here, the housing that the friction pads expand out on could be oval giving the same effect.......
probably of no use but thought id chip in!
Ben
Posted: 04 Aug 2010 06:45 pm
by pyro
ever get this sorted big boy?
Ben
Posted: 04 Aug 2010 07:30 pm
by volvosneverdie
pyro wrote:ever get this sorted big boy?
Ben
Fix it?
No.
I did the exact opposite.
I made it far, far worse.
Mission: check carb bolts are tight.
What a actually happened:
Overtightened one, stripped it, took it out, stared at it, tried to put it back in as best I could.
Then - took it for a test drive.
Lots of rattling. Thats not good.
Got stuck in traffic.
More rattling, hard to keep engine running.
Limped home, engine dies.
Can anyone guess what happened?
Well, I popped the air filter cover off and noticed there was a carb bolt washer missing.
Oh dear.
Think thats fallen into the carb without me realising then. And now its somewhere in the engine.
Which all adds up to quite a large fail.
Back to public transport for a while then.
Posted: 04 Aug 2010 07:42 pm
by pyro
im not even going to comment
i seem to remember some one with a b14 on here that you could drop in. or FJ drop in
could do that in a day i recon, only simple engines!!
Ben
Posted: 04 Aug 2010 07:50 pm
by volvosneverdie
pyro wrote:im not even going to comment
Ben
time.
thats the only problem.
plans are afoot.
for something slightly more interesting.
Posted: 04 Aug 2010 07:53 pm
by pyro
gig gig giggty goo.
pray tell?
Ben
Posted: 04 Aug 2010 08:01 pm
by volvodspec
bad luck Ben, but that engine is probably KIA. had the same thing a few years back, and the "new" grooves in the liners were way out of tolerance.
another B14 of the same model (and if the donor is a cvt too) can be in and running in 1,5 hour. i dare anyone to beat that record (and work alone offcourse)
Posted: 04 Aug 2010 08:08 pm
by volvosneverdie
volvodspec wrote:bad luck Ben,
Its kind of you to blame "luck" dude.
I think "idiot" is more accurate though.
pyro wrote:gig gig giggty goo.
pray tell?
Ben
Not THAT interesting man.
Wait and see.
If it doesnt come off, it'll be a b14 straight swap.
Problem is, its the RR gathering this weekend, Liams up to his back teeth in turbo swappage awesomeness and Johns got the manta to fiddle up.
So its just a matter of waiting patiently for a break in the storm of work and other commitments.
Theres talk of work begining shortly though, which is more exiting than xmas coming early.
Posted: 04 Aug 2010 08:13 pm
by macplaxton
Theres about 70 miles between you and a B14CVT engine if you're going in that direction.
Posted: 04 Aug 2010 08:15 pm
by volvosneverdie
Implied facepalm recieved.
Hopefully wont need it.
Pm coming at you though.
Posted: 04 Aug 2010 09:21 pm
by JPB
Posted: 04 Aug 2010 09:30 pm
by volvosneverdie
JPB wrote:
Oh well, it'll just be me, the Ashington RR guys and Ron's recently-MOT'd Dolomite 3500HL V8 at the pub meet on saturday then......
Unless some kind soul offers me a lift up..............
I said unless some kind sould offers me a lift up John....................................
Beers on me.
