Page 10 of 18
Re: 360 LSD.
Posted: 26 Nov 2013 10:09 am
by setsunakaede
Hi Miniswift,
Just let me know when Foggy orders, I'll try to have my financial means back in the healthy regions by then and order together.
Re: 360 LSD.
Posted: 30 Nov 2013 02:12 am
by driftking89
please develop me one for the 340 i know a fair few that will want one me and the old chap was thinking about engineering one but we have no clue were to even start
Re: 360 LSD.
Posted: 30 Nov 2013 12:07 pm
by miniswift
Hi,
Could anyone who has both 340/360 diffs confirm they are same?
As far as I know, they are same but I want to be sure rather than "I think so"!
Atchi
Re: 360 LSD.
Posted: 30 Nov 2013 01:20 pm
by peter schmidt
340-360 same diff
Re: 360 LSD.
Posted: 30 Nov 2013 04:13 pm
by miniswift
Hi Peter,
Thank you for that.
So this mean if you want 1 driftking89, you can buy what I get made!
Peter is using 1 with over 300+ Bhp so far.
Atchi
Re: 360 LSD.
Posted: 13 Dec 2013 10:55 pm
by miniswift
Hi,
There are 2 on order at the momeet for boys from here.
The manufcuturer's Lathe is dead and getting fixed as we speak this month. So there is slight delay for the delivery.
I will keep you informed.
Regards
Atchi
Re: 360 LSD.
Posted: 28 Dec 2013 01:50 am
by theo2468
Im going to be looking for an LSD soon
Re: 360 LSD.
Posted: 03 Jan 2014 09:46 pm
by driftking89
Defo and if anyone has a spare gearbox lying about that would be handy
Re: 360 LSD.
Posted: 20 Feb 2014 11:45 pm
by A.Finstad
Hei im new on this board and have just bought a 360 gl but it needs a LSD SOOOO bad!!! i have just right wheel drive at the moment it sems in a standard open diff, something is not rigth in the rear of that car
Miniswift can you send me a PM about shiping to Norway and price of this?
Re: 360 LSD.
Posted: 12 Mar 2014 11:12 am
by Kurre86
Hi!
I just installed my LSD (bought it at along with Peter about a year ago but haven't had time to fit it yet); installation was pretty straight forward, but not quite bolt on...
- Diff gear disc with markings for sanding/milling
First of all, the tolerances between the disc that forms the thrust bearing for the spiral gears of the diff and the crown wheel were slightly off. With a belt sander (might have worked with a good lathe and sharp tools), the outer diameter, the radius of the first edge, the height of the first flat part and radius of the second edge had to be adjusted slightly. Being hardened, it took a while to get everything to fit!
An important notice; if the disc is a tight fit, think twice before pressing it in since it is very difficult to get it out once pressed in if the fit has to be adjusted to make sure it sits flush with the surrounding area of the crown wheel. Peter made that mistake with one of his diffs, it took three 5mm drill bits and a lot of time to drill through from behind and press the disc out again!
- Shortened crown wheel bolts
The next thing that needed adjustment was the length of the bolts for the crown wheel; they were all bottoming out in the threads. Another trip to the beltsander and that problem was gone...
All in all, fairly straight forward, but not quite bolt on...
I managed to reuse the old bearings which were in good order, all I had to replace were the seals and gaskets and one of the shims to get the bearing preload right (the backlash between crown wheel and pinion was OK, it is generally not changed when changing the diff).
Re: 360 LSD.
Posted: 10 May 2014 08:45 pm
by miniswift
Hi,
I have sent 2 more LSDs.
I hope new owners will be letting us know how it goes.
Atchi
Re: 360 LSD.
Posted: 11 May 2014 09:23 pm
by FREJ
miniswift wrote:Hi,
Atchi
Yes I will, as soon as I get the LSD on the car!
Cheers from Sweden
Re: 360 LSD.
Posted: 17 May 2014 02:09 pm
by FREJ
Hello, now I have looked more closely at my Torsen that I received yesterday.
No problem with the disc fitment into the crown wheel, that Kurre86 showed higher up on this page.
Disc fitment into crownwheel is good.
But I found other issues:
Diff to big to fit into crown wheel.
Think I put the crown wheel into the lathe, instead of take a risk with the Torsen.
The drive flange doesn't fit into the gear with splines.. The hole seams/feels a little oval, Se images.
Maybe some hard work up 'n down with diamond paste could solve this?
The gear does not go all the way on to the drive flange.
Marks shows how the fitment is different around the hole. Oval?
And for the crown wheel bolts.. Kurre86 reported too long bolts. But I can't get them in at all!
My Torsen has M12x1,5 threaded holes for crown wheel but standard diff has M12x1,25?!
Suppose that this is a mistake from the making/threading of the Torsen. Or is there possibly M12x1,5 in some stock diffs?
Standard bolts for crown wheel. M12x1,25
Torsen threads for crown wheel. M12x1,5
//Frej
Re: 360 LSD.
Posted: 25 May 2014 07:47 am
by |2aebird
Any chance of getting one posted to Australia?
Re: 360 LSD.
Posted: 25 May 2014 10:22 pm
by miniswift
Hi,
I will send it to Oz, no problem but I have to sort out some issue first.
Atchi
