hi,
im checking that my carb is set up right but cant seem to find out what the float height should be or how to adjust it,
anyone on here know what the height should be or how to adjust it??
weber 32 dir float height?
- volvodspec
Re: weber 32 dir float height?
7mm including the gasket.
you hold the top of the carb upside down and measure the distance between the floater and the carburator
easiest way is sliding something that is 7mm thick inbetween; adjust with the floater's hinge at the floater needle valve (gently bend it)
cheers, i was starting to think no one knew
