How much torque can the 340 bellhousing take
Posted: 01 Feb 2012 02:12 am
by mrsoundcraft
Does anyone know how much torque this thing can handle?
How is it constructed and how could it be uprated?
Re: How much torque can the 340 bellhousing take
Posted: 01 Feb 2012 04:01 pm
by mat_91
On a 340 its not the bellhousing thats fails but the propshaft but with good alignment and a good prop about 150nm is about the most to be relable and uprated would up that to the gearbox limit of About 300nm if you dont drop the clutch from a dead start
Posted: 01 Feb 2012 07:43 pm
If you are modifying with a FWD engine I think you need a pilot bearing at the end to capture the clutch shaft, otherwise driveshaft alignment is the biggest issue.
