Page 2 of 2
Re: Gearbox mounts 360 GLT B200
Posted: 02 Nov 2014 10:36 am
Jon is in NI,
I've seen a lot of drift 360's break those cups so the problem could well be down to gearbox mount issues.
Posted: 02 Nov 2014 11:32 pm
by macplaxton
classicswede wrote:Jon is in NI,
Like I'm in NI? (for postal purposes
AFAIK he's physically in ROI.
Posted: 03 Nov 2014 01:34 am
by Logan360
mine is gones toos. I needs lots. like 3 cars worth o think.
Posted: 14 Dec 2014 12:52 am
So one of my mounts is cracked and wasted around the bolt holes for the bush, they can't be welded. My long term solution is 3d printing and moulding but short term I have made a reinforcing cover. I started thinking of washers but need support to connect the furthest away bolt. I'm not sure how strong this will be, but its worth a shot.
You could do a flat plate but the edges down the side would be very narrow and weak, it needs a 3d shape. I guess this is the purpose of the dome and edges.
I got a 73mm hole cutter and used some 2.5mm plate I got for engine mountings. If anyone would like a plate with a 73 mm hole as a starter I'll provide for a small price. 73 is slightly too small and needs chamfered but this was intended.
Posted: 14 Dec 2014 03:30 pm
Just remembered about this;
http://www.amazon.co.uk/Lumiweld-Kit-Al ... B00BSV6NW4
It might work, along with the strengthener. I'll give it a go I think.
Posted: 31 Dec 2014 03:27 am
Posted: 18 Jan 2015 04:46 pm
by miniswift
Hi,
If anyone can send me a photo of how it is mounted, I can design up in CAD to make steel plate.
I can get it laser cut in 3mm steel, stainless steel or so and weld it up by people. What do you think?
Do you need to have a dorme shape? If we make one to take a common poly bush, we should be able to make one easily.
iirc, there is a tab to fit into somewhere as locator and 3 sided for strength....
Atchi
p.s. just came on to see how you people are!
Posted: 28 Jan 2015 07:54 pm
I think the dome is needed for strength otherwise the part would need to be wider and would not fit. I'm not a mechanical engineer but stainless seems too weak/brittle for such a highly stressed part. Also it really needs to control the diff movement well, the original bush has sideways and vertical restrictions from the cross member and rubber insert, and its possible that CVs break when the diff rotates too much.
The cross brace seems useful but it is very hard to fit the strengthen once this is on. I could not remove the brackets from the diff once this was bolted on. Any cross brace needs to be a separate part, there is enough height in the standard bush bolts to fit the 2.5mm steel, this gives sufficient clearance to the cross member.
Posted: 02 Feb 2015 10:19 am
by alf
Howdy!
Can you use these, from a AUDI 80 III (berlina / 89, 89Q, 8A, B3) (2.0 quattro - 85 KW) ?
http://www.autokarma.ro/suport+transmis ... 38/10339/0 althought on site it does not appear the lenght between the holes.
Posted: 03 Feb 2015 08:32 pm
The bushes might fit but I would amazed if they were a match. Anyway the problem is also the brackets.
