so wondering about changing gear box fluid over some times it crunches in 2nd, so was looking at running dextron 3 transmission fluid. has any one done this or done anything else opinions would be great or a right up, or even a how to change the fluid, have never done any work to a transaxel befor.
thanks guys
gear box
gear box
Re: gear box
think it is dextron 3 ATF reccomended, or 10w40. 10w40 is quieter but more 'agricultural'
To change the oil is simple, drain plug out the bottom off the gearbox, once its all out - plug back in. Fill up slowly (especially on 5-speeds) through filler plug on cover at left hand side of gearbox, let it settle for 5 mins, top up if neccecary. Torques for plugs is 42NM iirc
Re: gear box
2nd was always a bit poor in 300s. I doubt changing the oil will make any difference. Crunching is unusual though, most likley clutch is sticky. Does the drive shaft stop when you put the clutch in? Just open the driver door and listen for it.
Unless the car has had a hard life you should not have any wear problems, with synchros etc.
Re: gear box
I have a slight baulk on first and an even slighter, occasional one on second. I changed the transmission fluid, and it made no noticeable difference. But still, it’s an easy job and probably worth doing anyway unless you’re going to replace the gearbox soon.
7.52pm: I'm jealous. I really wish that I was a) a Fulham fan; and b) at Craven Cottage. What a night for them. The players are still on the pitch, loving it.
http://www.guardian.co.uk/football/2010 ... eague-live
