340 turbo help? (trundle)
Posted: 24 Dec 2012 03:40 pm
by theashboi
so i have just got this old girl of T.J its a 340 1.4 with a b18ft i can do the engine pipe work and mechanical work fine but i am not very good at wiring :? any help would be much appreciated!
Re: 340 turbo help? (trundle)
Posted: 07 Jan 2013 01:20 pm
by jezypeti
Hi!
I have made a b18ft engined 360. So I could help you a bit.
First of all the grey-red wires are switched + by the 2 main relays (near the ECU).
Idle motor, O2 sensor, injectors...
Gray can be after ignition +.
But the red wire could be the third pin for idle motor (if it goes to ECU pin 10)...
If you want some pics, please send pm.
(sorry for my english)
Posted: 15 Jan 2013 07:06 pm
by theashboi
Thanks for the help mate pics of your's would be good if you can
Posted: 16 Jan 2013 12:41 pm
by jezypeti
Pics of the enginebay. Sorry for gopro.
I dont think, this would help you...
If you are interested in some details, please ask!
Posted: 16 Jan 2013 02:35 pm
I wish my B18ft not done project was left hand drive!
Good use of the 360 air box too.
Posted: 16 Jan 2013 06:34 pm
by theashboi
Pics don't help my engine bay looks a lot different :? I will take sum pics when I get home later it is just sum wiring to do and it shod start the pump and sender are in the tank fuel lines are in rad pipes and oil are dun along with the throttle and new starter motor just need the little bit of wiring left so frustrating sm2
Posted: 16 Jan 2013 10:23 pm
by jezypeti
For startermotor, you can use the stock wiring harness (blue-yellow wire I think). And you need only connect it to the battery too.
Right hand drive... I couldnt drive from there :oops:
I'm witing for pics.
(It was 360, so I have the battery tray in good location. And the air box is stock :mrgreen: )
Posted: 16 Jan 2013 11:33 pm
by theashboi
i have dun the starter motor i just need to know if any of these need to be connected i was told the big bunch of wiers are not needed ?
Posted: 25 Jan 2013 10:02 am
by T.J.
you have been busy :) I see fuel lines and all the water hoses are done.
The coiled up wires coming from the alternator should be for the old 480 infocentre, so hopefully you can just cut them off. The 3 (blue/orange/white) are for the original ignition coil.. just look it up in the haynes book ;)
Posted: 25 Jan 2013 02:39 pm
by theashboi
i have done the fuel lines thay are just long at the moment because thay need to be cliped up at the back the in tank pump is in and plumbed in (that was fun!) rad pipes are dun took me 3h at a scrapyard to find two pipes that would fit lol one of a laguna and one of a old austin metro van. i have also put a new starter motor on as the old one was just old and slow oil and filter done new plugs lucky i did as the inlet manifold was full of metal filings :shock: all thats left to do is the wiring and exhaust im going for a 2inch straight through exhaust with a 2 inch cherry bomb back box :D
Posted: 25 Jan 2013 02:57 pm
by T.J.
theashboi wrote:the inlet manifold was full of metal filings
wow.. glad you spotted that. previous owner never mentioned it. Guess they're left behind after the throttle body swapped ends.
