IDLE SOLENOID AVAILABILITY?
Justin
Post by Justin » 31 Jan 2013 12:10 pm
Does anyone know where I can get a new idle solenoid for my 1988 1.4 Volvo 340DL which has a Weber carburrettor? The part number would be very helpful aswell...
1988 340 1.4 DL
Re: IDLE SOLENOID AVAILABILITY?
Post by pettaw » 31 Jan 2013 01:43 pm
I got your PM, sorry hadn't replied sooner, but needed to get my research done.
Webcon is the place to go to. Its a Idle Solenoid for a Weber 32 DIR, and the part number is 4391104704, the price is 29.34 + 2.95 P&P and VAT. I have phoned them and they have them in stock, but a limited number only. The phone number is 01932 787100.
The guy I spoke to did mention that its important to just make sure that you have a 12V supply running to the idle solenoid wire, so worth just checking with a multimeter whilst its plugged in and the ignition turned on.
Hope that helps.
morgan105
Post by morgan105 » 31 Jan 2013 01:56 pm
Occasionaly they come up on the bay but not often.
Totally agree with checking the feed wire for power first as that was the problem on my 2nd volvo. If you think this is the problem you can verify it by getting a piece of wire and taking it from the battery positive to the solenoid.
Justin
Post by Justin » 31 Jan 2013 04:21 pm
Thanks, I will check the feed wire tomorrow. What is the other connection for, an earth possibly?...
1988 340 1.4 DL
Post by bogbasic » 31 Jan 2013 04:31 pm
Daffhobby.nl is yer place.
Post by macplaxton » 31 Jan 2013 05:41 pm
I second Webcon as the place to go for this.
No point in splashing the yoyos when the exchange rate is poor and the said part can be got in Blighty. :wink:
Justin
Post by Justin » 31 Jan 2013 06:44 pm
I checked the feed wire a little earlier with just the ignition turned on and its getting 12volts, but in short equal pulses which I guess is normal? My solenoids knackered however as I foolishly cut the needle inside and my car is now running like an absolute pig! Off to the scrappy tomorrow and if that doesnt work a phone call to webcon...
Interestingly my local Volvo dealer has just replied to an earlier email I sent them regarding getting a new idle solenoid, not surprisingly the part is no longer available but the part number they supplied was 3342556 which is different to the one above?...
1988 340 1.4 DL
Post by macplaxton » 31 Jan 2013 08:30 pm
Justin, Please read the second post properly. The number given is the WEBER part number and not the Volvo one.
Now, I am unable to reply to you PM as I get the error "Some users couldn’t be added as they have disabled private message receipt." If you wish for me to reply here in the thread, then please let me know. If you wish for me to reply by PM, then please enable private message receipt in your user control panel settings.
Post by macplaxton » 01 Feb 2013 03:23 am
Here's what a fuel-cut off relay on a MY87 onwards B14.4E car look like:
fuel_cut-off_relay by macplaxton, on Flickr
It is found on the passenger side inner wing.
The wiring diagram for it is in the green book wiring diagrams, found in the technical resources section of this forum.
Cars fitted with the above relay have two wires going to the carb. 1) to the idle jet solenoid, 2) to the throttle stop (makes contact when throttle is closed)
I cannot offer any further guidance than that. If you don't know what you're doing, get someone who does to do it.
Justin
Post by Justin » 01 Feb 2013 03:43 pm
macplaxton wrote:Justin, Please read the second post properly. The number given is the WEBER part number and not the Volvo one.
I apologise. I think I've just enabled private message receipts in my user control panel settings?
1988 340 1.4 DL
Justin
Post by Justin » 01 Feb 2013 03:44 pm
macplaxton wrote:Here's what a fuel-cut off relay on a MY87 onwards B14.4E car look like:
This is exactly whats on my car...
1988 340 1.4 DL
Justin
Post by Justin » 01 Feb 2013 03:58 pm
I emailed Webcon yesterday regarding the idle solenoid and the link to the picture they've sent me shows a completely different solenoid with a circular barrel as opposed to an hexagonal one like mine!
I did manage to get a secondhand solenoid from a scrappy today, tested it for the click but heard nothing so fitted it anyway. My engines all over the place, keeps cutting out and then revs faster and also makes an embarassing whirring noise...
Just hope I can find another solenoid somewhere?
My current idle-solenoid
Webcons idle-solenoid
1988 340 1.4 DL
Re: IDLE SOLENOID AVAILABILITY? (ZERO HOPE)
Post by bogbasic » 02 Feb 2013 09:16 pm
Oh well, if you contact Danny at dafhobby he'll do the right part. I got one from him a few months ago and it works wickedly well ;-
Justin
Post by Justin » 05 Feb 2013 12:36 pm
That one is the same as Webcons one, a cylindrical body as opposed to an hexagonal one.
1988 340 1.4 DL
