F7P head gasket
Posted: 22 Apr 2013 06:37 pm
by scamparoo
Okay so head went the other day, just a few quick questions, firstly what is the maximum the head can be skimmed? And when rebuilding the valve train do you have to do anything specific, such as with the hydraulic followers and any other key point?
Also what is the revised limit for the f7p?
Re: F7P head gasket
Posted: 23 Apr 2013 05:28 pm
by 340GLT
Most machine shops should have the data for the maximum a head can be skimmed, as for valve train clean all the valves, ideally the lifters want to be fully submerged in a pot of engine oil so they work all the air out then fit them into teh engine. I would definitely replace all the valve stem oil seals while you are there.
What do you mean by revised limit of the F7P??
Re: F7P head gasket
Posted: 23 Apr 2013 07:32 pm
by scamparoo
Cheers for that and I ment rev limit?
Re: F7P head gasket
Posted: 25 Apr 2013 07:32 pm
by scamparoo
What are the torque settings for a f7p head bolts, cam holders and rocker cover? Need reply ASAP guy's
Re: F7P head gasket
Posted: 01 May 2013 03:00 pm
by Alex Laidlaw
In here from pg. 19 onwards, F7P and F7R are mostly the same. There is a better quality pdf version of this floating about the internet somewhere.
http://www.scribd.com/doc/19561301/CLIO-WILLIAMS-MANUAL
