Just wondering what might be the cause of the grinding (sounds like metal on metal) when finding reverse on my 360 GLT. No grinding when selecting any other gear. Any ideas
Kelvin
Clunking and grinding when finding reverse
Re: Clunking and grinding when finding reverse
Try when it goes to make that noise, a clutch down, into first, out of first, clutch up then clutch down for reverse again.
If it's what I think (and it doesn't try to grind on the second go), it's nothing to worry about.
I do that wi mine too only i don't play with the clutch as much. if i grind's i put it into first then back to reverse.clutch down.
Own:
86 360GLT
97 S90
92 960S, Royal
01 Subaru Lancaster 6
96 Volvo 854R
Owned
E90 320 M-sport wagon
S60T -Mazda Familia
850lpt -AU Falcon
855T5 -91, 95, 97 960
940TIC -Mitsi GTO TT
16x 360-Toyota corolla
Toyota corona-R32 Skyline
V70R -V70T5
86 360GLT
97 S90
92 960S, Royal
96 Volvo 854R
Owned
S60T -Mazda Familia
850lpt -AU Falcon
V70R -V70T5
Just a small disadvantage of the gearbox at the back, takes a bit longer for the drive shaft to stop rotating. Pushing it into a synchromesh gear like 1st or 2nd stops the shaft, reverse has no synchro.
Another problem is a sticky clutch, if it doesn't move easily on the shaft it will keep rotating and 1st will be more difficult.
