HELP! twin carbs ignition
cgray93
Post by cgray93 » 05 Dec 2013 07:57 pm
going to be converting my 360 to twin webbers but need advice on what to do about ignition. can I still use the renix? or is it possible to remove and replace with an aftermarket ignition system? eg omex megasquirt etc. and if so what exactly is involved
Re: HELP! twin carbs ignition
Post by Ride_on » 05 Dec 2013 09:06 pm
If this the only mod I don't think you will exceed the ignition map. Ignition more depends on cam, compression, octane.
cgray93
Post by cgray93 » 05 Dec 2013 09:16 pm
I plan on fitting a cam in the future and possibly head work as and when I get money so ideally want something that would get the most out of those mods. hence why I figure an aftermarket mappable ignition system would be the best route?
Post by classicswede » 06 Dec 2013 12:29 am
123 ignition do a bolt in programmable distributor or you could fit something like megajolt
Post by volvodspec » 06 Dec 2013 01:57 pm
so if you feel comfortable about megasquirt and the others mentioned, why not skip Webers and go for a ITB setup?
thododd
Post by thododd » 06 Dec 2013 02:49 pm
Full engine management is generally 3-4x the price of ign only
cgray93
Post by cgray93 » 06 Dec 2013 07:54 pm
volvodspec wrote:so if you feel comfortable about megasquirt and the others mentioned, why not skip Webers and go for a ITB setup?
Already have the carbs and the manifold. Just trying to find out if I can run the standard ignition set up or if I'll need to change it.
classicswede wrote:123 ignition do a bolt in programmable distributor or you could fit something like megajolt
Will have a look at that 123 ignition cheers
derskine
Post by derskine » 08 Dec 2013 03:14 pm
Webers are cooler!
1984 Volvo 360 GLE Saloon
1987 Volvo 340 1.7GL
Additionally -
1966 Ford MK1 Cortina
1971 Hillman Imp
1984 Renault 18 GTD
