940 Turbo
Mcglone7
940 Turbo
Post by Mcglone7 » 03 Feb 2014 07:24 pm
Hello,
does anyone know what the thread is on the 940 turbo's for oil inlet/outlet. Also the same for water feed too.
Re: 940 Turbo
Post by classicswede » 03 Feb 2014 08:41 pm
The oil filter is 3/4 unf iirc
If you are on about the fittings on the turbo, the water connections are bolt on fittings. Not sure what the oil feed and return threads are off the top of my head but they are a standard thread common to most turbos.
Mcglone7
Re: 940 Turbo
Post by Mcglone7 » 03 Feb 2014 08:50 pm
Cheers for that, i think i've found it on ebay. 12.5mm common banjo bolt size.
Nimminz
Re: 940 Turbo
Post by Nimminz » 07 Feb 2014 11:38 am
m12 x 1.5 pitch banjo's
Re: 940 Turbo
Post by filthyjohn » 19 Feb 2014 11:01 pm
The oil outlet is a plain pipe with a bolt either side and a gasket.
