volvo 360 wont start hlep b230f inside
drlove66
Post by drlove66 » 20 Feb 2014 07:01 am
hello everyone I'm ALL THE WAY IN JAMAICA ,,, """i got Volvo 360 gle """ it all starts here i swap in b230f bottom half and use the same b200e head on it ,alone with d water pump flywheel and etc.... now for the pass week trying too start the car it just wont fire!!!! i'M getting current at the plugs fuel pump is working FINE gas is in the line > but injector wont fire, getting no pulse single >>> the positive relay that goes too the injector is working fine "i add use a test light and check it out " I AM just not getting any negative single too d injector """ ever thing on d wire loom in connected except the >>>>Thermal Time Switch >>>ADD BROKE OFF """ add took out the ecu and add a friend check it out he say its OK no burns r anything.... add check d wire loom with auto vote meter there was no break wires on it !!!!!! so what do u think i most check out the wiring is form the same volvo 360 u all can add me on whats app at 18763582242
Re: volvo 360 wont start hlep b230f inside
Post by classicswede » 20 Feb 2014 09:45 pm
What flywheel did you use?
drlove66
Post by drlove66 » 21 Feb 2014 03:35 am
the same 1 that came with the 360
Joris
Post by Joris » 21 Feb 2014 08:33 am
are you sure its fitted in the right position?
drlove66
Post by drlove66 » 25 Feb 2014 08:14 pm
sorry for the delay in my reply the car add wire wrong that's why it was not sending any pulse single >>>> but now i'm not getting any current at d plugs
drlove66
Post by drlove66 » 25 Feb 2014 08:18 pm
not sure yet about d flywheel as yet but the starter turn the engine over just fine and if its in gear it jumps to drive
drlove66
Post by drlove66 » 03 Mar 2014 04:03 am
got it starting now !!!!!
