volvo 360 wont rev out flat
next problem i have i put in a b230f engine. in the 360gle but i can get d engine too rev out flat... going too race the car ...when it reach too 4,000 rpm to 3000rmp it's misfiring (no gun fire sound) and i don't see any leaks and where what most check on too get it too rev out
Re: volvo 360 wont rev out flat
Is the timing right? and how is the fuel pressure?
I'm sure the time is rite because, it wood not have start if it was wrong on less the distributor timing is wrong... HOW TO CHECK IT???? i bought this too replace the pump tell fi this pump is ok for it http://www.ebay.com/itm/In-line-high-pr ... 1152402795
Sounds similar to the problem I had, it was the timing belt. The car did run pretty well even though it was wrong just was flat and slow to rev and misfired a bit
