volvo 340 with 440 engine conversion
driftingmonkey
Post by driftingmonkey » 28 Oct 2014 03:51 pm
hello ! I have a Volvo 340 with intentions of putting a Volvo 440 1.7 turbo engine into it what gear box and diff would/could I use ? HELP
Joris
Re: volvo 340 with 440 engine conversion
Post by Joris » 28 Oct 2014 05:40 pm
The ones that are in the car at the moment?
driftingmonkey
Post by driftingmonkey » 28 Oct 2014 05:45 pm
but will the diff and gearbox and prop be strong enough ? ive got a 1.4 in it at the moment and don't think it be strong enough
Joris
Post by Joris » 28 Oct 2014 05:49 pm
What are your goals? Prop will not last but the gearbox and diff will hold up to about 200/250 bph.
driftingmonkey
Post by driftingmonkey » 28 Oct 2014 06:16 pm
somewhere about 130/140 bhp ish intentions is to drift it and learn in the 1.4 then go for the 1.7 turbo
Post by classicswede » 29 Oct 2014 10:46 am
The main thing you will need is a prop upgrade, the gearbox will be fine but any gearbox can break when drifting. You will also want to add a second torque arm to the back axle.
You will need a lot of 1.7 engine parts and bellhousing to fit the 440 engine
