B14 hard to start
jakz17
B14 hard to start
Post by jakz17 » 30 Nov 2015 02:10 pm
Hi i have finally buy my 340 with the 1,4 Motor
The car is hard to start i need to "pump" on the clutch and then press the gaz a lot or it turn off.
Where can i start my skills are non existence for older car.
I think that checking the carburator may be a good start ?
Re: B14 hard to start
Post by Ride_on » 30 Nov 2015 08:24 pm
Firstly, Is it hard to start (fire the engine), or hard to pull off (accelerate), or hard to keep it idling?
Pumping the clutch should not have any effect.
I'd start with a workshop manual, and also read the owners manual on how to start it:
Apply some choke (depending on temperature) and pump the accelerator 3 times before turning the engine over.
Which year of car?
Post by bogbasic » 30 Nov 2015 11:57 pm
Pull out the choke as you turn the starter. Clean inside the dizzy cap.
jakz17
Post by jakz17 » 01 Dec 2015 09:06 am
Ride_on wrote:Firstly, Is it hard to start (fire the engine), or hard to pull off (accelerate), or hard to keep it idling?
Which year of car?
Thnaks for the reply sorry i forgot some info so it's a 1990 b14 and i mean hard to fire the motor.
I know that pumping the clutch should not have any effect but strangely it does ? ...
when the choke is on does the plates close entirely ?
I don't have the manual i will try to pump 3 times i did only 1.
Post by bogbasic » 01 Dec 2015 01:29 pm
Choke is for increasing the richness of the fuel-air mixture. Plates is to do with the clutch? Some people always press the clutch so that the starter motor does not have to turn the propshaft so, yes, it can start quicker if you do that.
Post by Ride_on » 02 Dec 2015 08:52 pm
There are many causes so its not possible to diagnose just from the symptom, but I would start with trying to determine if its fuel or spark related. Check the fuel is available by pumping the accelerator with the air filter removed, you should see fuel squirt into the chamber. Check spark with an in-line spark checker.
360beast
Post by 360beast » 03 Dec 2015 10:43 am
bogbasic wrote:Choke is for increasing the richness of the fuel-air mixture. Plates is to do with the clutch? Some people always press the clutch so that the starter motor does not have to turn the propshaft so, yes, it can start quicker if you do that.
Plates he means the butterfly valves on the carb
jakz17
Post by jakz17 » 03 Dec 2015 11:09 am
Yes thanks that's what i mean.
I've download the v3m technicals and i will start by adjusting the carburator and check the ignition.
I found that i have a problem with the choke too when i pull the choke the valves close but when i push the choke it stay close i've got to push it manually. So a big recoditionning of the weber is a good start i think.
360beast
Post by 360beast » 03 Dec 2015 02:14 pm
Try cleaning and lubricating the spring for the choke, mine was a bit sticky on my Golf so I did that and it returned fine afterwards
jakz17
Post by jakz17 » 07 Dec 2015 10:55 am
360beast wrote:Try cleaning and lubricating the spring for the choke, mine was a bit sticky on my Golf so I did that and it returned fine afterwards
So i've clean the weber and it's much better. I've also check the spark plug and 1 is damaged so there is a problem here too With 4 new sparks plug it will be great :roll:
jakz17
Post by jakz17 » 16 Dec 2015 09:02 am
With 4 new spark plug it's perfect :)
