How to test propshaft
Posted: 10 Apr 2017 11:54 am
by jakz17
Hi, i have a B144E that i'm building to drift.
I want to know how to check if my propshaft is "ok" so i don't break it ?
Is there a way to upgrade the propshaft ? Because for now B14 is ok as i'm a noob but i will swap (b18ft /f7r) later and with more power it might break sooner.
Sry for my english.
Re: How to test propshaft
Posted: 10 Apr 2017 07:11 pm
by 360beast
First of all replace your engine mounts with polybushes as chances are they are old and sagged which causes it to be out of alignment which will then break your propshaft.
Posted: 11 Apr 2017 08:39 am
by jakz17
Thanks for your reply
Are B17 and b14 engine mounts compatible or are they different ? Because i don't want to spend on new engine mounts for an engine that will not last ?
Posted: 12 Apr 2017 06:06 am
by 360beast
As far as I know they are the same.
Posted: 04 May 2017 08:36 pm
The rear mounts are all teh same and later 1.4 and 1.7 mounts are the same.
If the prop and gearbox are not perfectly inline with each other then the rubber in the prop will overheat causing failure. The higher you rev the engine the worse the problem. Jerking the clutch is also not a good idea
