Volvo 1.7 Turbo
Posted: 18 Mar 2018 09:36 pm
by Brian 200
Hi all,
I am currenting building a Volvo 340 2 door with a 1.7 turbo engine from Volvo 480 ( was an auto)
Ive been searching all over but can't seem to find what i need to do the conversion. The car is currently a 1.4 but I do have a 1.7 for spares.
Do I need to swap sumps over from my standard 1.7 engine to turbo engine?
Use 1.7 bellhousing and what flywheel do I need?
Can I use standard 1.4 engine mounts/front brace bar?
Many thanks,
Brian.
Re: Volvo 1.7 Turbo
Posted: 19 Mar 2018 07:07 pm
Brian 200 wrote:Hi all,
Do I need to swap sumps over from my standard 1.7 engine to turbo engine? yes
Use 1.7 bellhousing and what flywheel do I need? 1.7 bellhousing and 480 manual turbo flywheel
Can I use standard 1.4 engine mounts/front brace bar? if a later 1.4 yes if early then you will need the one from teh 1.7
Many thanks,
Brian.
Answers in red
Re: Volvo 1.7 Turbo
Posted: 20 Mar 2018 07:47 pm
by Brian 200
Thank you for replying, My Volvo is on F reg which makes it one of later ones. Can I use the mounts off 1.4 engine for turbo engine as I cant seem to see how it lines up somehow.
Thanks,
Brian.
Re: Volvo 1.7 Turbo
Posted: 20 Mar 2018 07:51 pm
by 360beast
It will probably look weird lining up the mounts as the turbo engine is from a FWD car and yours is RWD
Re: Volvo 1.7 Turbo
Posted: 20 Mar 2018 08:50 pm
The mounts are the same but you need the 1.7 brackets
Re: Volvo 1.7 Turbo
Posted: 20 Mar 2018 09:46 pm
by Brian 200
Thought as much, thank you for your help. 340pw
Re: Volvo 1.7 Turbo
Posted: 30 Mar 2018 06:53 pm
by Brian 200
Finally got around to do the clutch layout, Which turbo flywheel do I need as Ive been told theres two types? also do I need a pilot bearing?
Is there any for sale?
Thanks.
Re: Volvo 1.7 Turbo
Posted: 01 Apr 2018 10:33 pm
by Brian 200
Sourced a flywheel. Do I need to use standard 1.7 340 clutch or 480 clutch aswell?
Thanks.
Re: Volvo 1.7 Turbo
Posted: 02 Apr 2018 11:09 pm
1.7 friction plate and bearings, Turbo cover
