Because of our MOT system I need to fit carb back to car and I thought to look into carb a bit, check all that is stated in Haynes book and also what I have read from this board.
Haynes says that float height should be adjusted so that it is 33,8mm measure from seal to edge of float, while spring loaded ball is not compressed.
Well, I did measure and it was something near 50mm, so what does this affect? I would guess that it means lean mixture because of fuel shortage, but am I wrong?
So I did adjust it to somewhere near correct value, it was not too easy to get precise measure as spring in that ball is quite weak and my measuring equipment was not correct to job, but I think it is now near 40mm, but I did not like to adjust it too much as now already ball is compressed just when float touches that base where it is attached, so any more and it may flood?
This leads me to believe that whole float thing might be twisted by some previous repair shop, that has tried to adjust it wrong.
I have not yet installed this as I need to find my manifold that is somewhere in cellar under mountain of stuff
Anyway I would like to know if I have understood how this thing works correctly so I won't end up engine room covered with gas
Other things mentioned in Haynes were weight of float, which may or may not be in spec, I can't measure anything that light, then idle mixture base setting, that I did set. Also there was test for float if it leaks and there was no sign of air bubbles.
Magnetic valve would need new o-ring as current one is snapped, must be that I have tighten it too much at some point, but could not see much other problems, filters were ok and those things that has holes in them and are screwed to place seemed to be ok and no dirt there (3, one at top plate and two at center of lower part).
Also I cleaned thing as well as I could, but I have no possibility to use strong chemicals for cleaning so it could use better cleaning with gasoline and compressed air, however I don't like to mess with gasoline inside of house and neighbourgs might not like if I do that at parking lot so makes things bit more challenging.
Perhaps tomorrow I will fit it on place and do other MOT checks, so if you have some tips for this carb before that all is appreciated
