injection conversion
Posted: 12 Aug 2006 01:16 pm
by pyro
hello all im thinking of converting my 360 gle onto injection - will the manifolds just swop straight over? obvioulsly i will need the ecu - where is the best place to fit it? - also what sort of mpg (long run at 60mph) would i expect from it on carbs compared to injection?
cheers - ben
Posted: 12 Aug 2006 01:26 pm
Please don't fit the original 360 injection system... you'll be wanting to look at Megasquirt. The 360 carb is much better on fuel than the injection on a long run.
Posted: 12 Aug 2006 02:34 pm
by jtbo
Manifold will fit, but you need to block water circulation holes from head as injection manifold will not have this water circulation.
Then you will need to install one temp sensor to cylinder head, there should be place for this.
Throttle cable is different.
Fuel pump is needed too, also new fuel lines unless one likes to play with fire.
Some electric works needed too, grab injection model wire harness, makes life easier.
To go with megasquirt or stock ecu route is then something to decide, with megasquirt you get better fuel economy and it is simpler to install / diagnose in certain aspects, but some tuning is needed, also laptop is needed etc. I would choose megasquirt, but stock efi is perhaps better for install and forget type of use.
Posted: 12 Aug 2006 08:24 pm
by pettaw
If you're happy to fiddle, then megasquirt is the way to go, but I agree with Jani, if you want something that's easy to set up then go for the original LE-Jet, when its working properly its not that much slower than MS anyway.
Posted: 12 Aug 2006 10:08 pm
by Gulbrandsen_Racing
You would probably feel a difference if you switch from LE-Jetronic injection, and to MS.
But i don't know if you WANT to use MS. The costs aren't that different from a complete LE-Jet injection-system.
And you have to change your fuel-tank..!
Posted: 12 Aug 2006 11:47 pm
by Ronnie
It would be much easier and probably cheaper to change your car than it would be to change the fuel management system - get yourself a GLT!
Just my 0.02p's worth...
Posted: 13 Aug 2006 10:46 am
I don't know, whats the reason behind the change? If I was going to run a stock 360 and had no future upgrades planned, the GLE carb has to be the best overall I reckon.
Posted: 13 Aug 2006 04:41 pm
by jtbo
Gulbrandsen_Racing wrote:You would probably feel a difference if you switch from LE-Jetronic injection, and to MS.
Certainly fuel tank doesn't need changing, one can easily take fuel to pump from hose that connects two tank sides and return fuel would then enter to tank from top.
It is also possible to use those original fuel hose connections, it did worked just fine and my fuel pump was in engine room as I find it safer to have very short pressurized fuel lines.
Posted: 13 Aug 2006 07:39 pm
Ohh, thats an intresting bit of news Jani... I'll pm you about that in a few weeks!
Posted: 14 Aug 2006 06:33 pm
by pyro
well it was just a thought i'd put no serious thought in to it - but it looks like ill keep the carb itll be a hell of alot easier - i have the capability to do it just not the time! - i use it everyday!
it has recently developed a petrol leak in the engine bay from one of the braded fuel hoses - tad annoying! right next to the dip stick and the inlet manifold!
cheers all
Posted: 14 Aug 2006 06:36 pm
by jtbo
Replace all those original fabric covered hoses, saves fuel too, there is some of them under the car too and above fuel tank.
Oh yes, prevents from car getting fire too.
Posted: 14 Aug 2006 06:41 pm
by pyro
hmm thanks for that - its always an advantage when your car doesnt catch fire!
Posted: 14 Aug 2006 07:04 pm
by jtbo
Here is pic, left is front of car:
Posted: 30 Sep 2006 07:30 pm
by pyro
cheers matey will get them all changed asap,
